i think you will be surprised how many of us run catch tanks, most i would say, i got mine direct from forge for around the same price as those with the benefit of good brand name
off the top of my head i think its 15mm, ye u just need two pipes and to run it off the pipe that comes from under inlet mani to the rocker and take out pcv valve which is a bit of a *******
yes they are all universal just depends on bore size really mine came with two different outlet adapters 9mm and 14mm iirc so you could use either
Your oil breather is 19mm, so the closer to that the better.
Also, will you use one port to re-route back to the TIP or do you want to vent to atmosphere?
Which ever is better for the engine or is that not the case & it just for looks?
