lawrieIbizaMk4
Team Boc!
Aug 31, 2009
3,498
Milngavie, Glasgow
www.bebo.com
was driving to work this morning nd a van followed me into the petrol station nd the guy said my reverse light was randomly flashing as i was driving along, thought it might go away but it has continued through the day.
also realised my rear wiper has also been stuck on all the time even when in the off position
any1 else had this problem?!
advice would be gretatly appreciated
was thinking it might be my rear hose leaking into a junction box?
I'd hope that you have two different faults, firstly a u/s reverse light switch and secondly a problem with either the control voltage to the rear wiper or a fault inside the wiper motor housing, or a faulty stalk (switch). Remember these wiper motors have a constant supply and a second control supply so that they can always return to the park position when the control voltage is removed.
You lucky person, but that still wastes some of your time though!
Maybe read the very small print on your warranty docs first - just in case!
my mate said today it might be a bad earth? any1 know where the main earth point is?
That is always a possibility when you have two otherwise unrelated electrical problems. I'd hope (for any other Ibiza owners) that u/s earths are not normally the problem with these cars, and now a coil failure! Well they can occur anytime - maybe push the point that "it might be a manufacturing batch failure" so "or you replacing them all?" - its worth a try and it shows that you are aware that VAG know that lots of cars do have coil problems - maybe someone on here can remind us of the retro-fitted extended warranty that coil packs now have - it might be 4 years, not so important in your case as your still have warranty cover, but it might be useful for folk just out of normal VAG warranty - and who are having coil pack trouble.
