any 1 used 1 of these http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=190202TUN&product=FMEGRBP
have you used it DPJ
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
I thought you needed to put a resistor across the SAI plug to stop the fault codes?
http://uk-mkivs.net/forums/p/141240/940861.aspx
It goes on the lower front half of the engine.
The plate actually replaces a valve which is bolted to the side of the cylinder head. This is where the secondary air is injected into exhaust port #4 (before the port leaves the head at the rear)
