How do you refit the bumper properly?
I have had mine off a few times with the laguna FMIC too, and never had to back on without having a big gap inbetween the bumper and the lights/arch.
do you mean that the headlight does not go flush with the front wing![]()
only thing that could think is that your intercooler is touching the inside of the bumper have you cut any of the bumper plastic out??. as i know i had to take a fair bit out when i put my intercooler on
Nah I don't think it's that. I did cut off some and it fits fine that way, it's vertically it doesn't fit well. When putting the bumper on, which groove do you slide the side bits into?
I might just take it off and have a right good go at it sometime...
What size are the torx screws when taking the front bumpe off? 10mm?
Anyone know the size?
I knew I should have taken more time to write it!
No the bumper doesn't sit flush with the light and wing![]()
Thanks mate, it was the ones when you open the bonnet on top. Car failed its MOT on side light out, which i knew about, and the registration plate bulbs. Anyone know the sizes or type of the reg bulbs?
You talking about the top line of the bumper and the front quater pannel.?
If so mine is the same i couldnt get it to fit as flush as it did before you can kinda see here.
