apples
jake
I AV MOSTLY BEEN BEATING
Feb 2, 2003
2,666
rochdale
Visit site
did a few logs of the lcr tonght, outside temp was 0oC so though why not lol
i think they look pretty good tbh
Code:
Friday	29	January	2010	18:04:58
1ML 906 032 A		1.8l R4/5VT         0002
	Group A:	'002				Group B:	'020				Group C:	'115
		RPM	Load	Inj. On Time	Mass Flow		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME					TIME					TIME
Marker	STAMP	 /min	 %	 ms	 g/s	STAMP	°KW	°KW	°KW	°KW	STAMP	 /min	 %	 mbar	 mbar
	0.29	2520	32.3	2.72	15.69	0.6	0	0	0	0	0	2480	32.3	970	990
	1.21	2960	69.2	7.14	44.17	1.51	0	0	0	0	0.91	2760	58.6	970	1000
	2.11	3040	15.8	1.7	5.94	2.41	0	0	0	0	1.81	3360	45.9	970	1150
	3.02	2240	68.4	7.14	33.61	3.32	0	0	0	0	2.72	2280	48.9	970	990
	3.92	2600	66.9	5.1	34.69	4.22	0	0	0	0	3.62	2520	72.9	1040	1130
	4.83	2880	49.6	4.42	23.03	5.13	0	0	0	0	4.53	2800	66.2	970	1190
	5.73	3080	39.8	3.74	22.19	6.04	0	0	0	0	5.43	3000	47.4	970	1070
	6.64	3120	23.3	2.04	12.47	6.94	0	0	0	0	6.34	3120	29.3	970	1020
	7.54	3160	31.6	2.72	19.94	7.85	0	0	0	0	7.24	3120	31.6	970	990
	8.45	3160	22.6	2.04	13.78	8.75	0	0	0	0	8.15	3160	25.6	970	1000
	9.35	3320	63.2	6.46	43.64	9.66	0	0	0	0	9.05	3240	60.2	970	1010
	10.26	3160	15.8	1.7	5.25	10.56	0	0	0	0	9.96	3480	48.9	970	1200
	11.16	2560	109	11.56	63.75	11.47	0	0	0	0	10.85	2840	93.2	1840	1020
	12.07	3000	191.7	20.4	151.42	12.37	0	0	0	0	11.77	2840	171.4	2260	1740
	12.98	3640	191.7	21.42	157.28	13.28	0	0	0	0	12.67	3400	191.7	2300	2270
	13.88	4280	191.7	21.42	184.67	14.18	0	0	0	0	13.58	4040	191.7	2320	2260
	14.79	4880	191.7	20.74	200.53	15.09	0	0	0	0	14.48	4720	191.7	2330	2360
	15.69	5480	191.7	21.08	219.11	15.99	0	0	0	0	15.39	5280	191.7	2270	2280
	16.6	5960	191.7	19.38	225.44	16.9	0	0	0	0	16.3	5800	191.7	2230	2180
	17.5	6360	181.2	17.68	228.67	17.8	0	0	0	0	17.2	6240	191.7	2110	2080
	18.41	5920	13.5	1.7	0	18.71	0	0	0	0	18.11	6480	48.9	970	2540
	19.31	4560	15	1.7	11.19	19.61	0	0	0	0	19.01	4920	14.3	970	1090
	20.22	3200	13.5	0	8.39	20.52	0	0	0	0	19.91	3640	12.8	970	1010
	21.12	1960	15	0	5.61	21.41	0	0	0	0	20.82	2360	14.3	970	1000
	22.02	1200	16.5	1.7	3.25	22.33	0	0	0	0	21.71	1320	15.8	970	990
	22.92	960	17.3	1.7	3.22	23.23	0	0	0	0	22.63	1040	18	970	970
	23.83	800	19.5	2.04	3.06	24.13	0	0	0	0	23.53	840	19.5	970	970
	24.73	760	19.5	2.04	3.03	25.03	0	0	0	0	24.43	760	19.5	970	970
second run
Code:
Friday	29	January	2010	18:07:03
Marker	Group A:	 Not Running				Group B:	'031				Group C:	'115
							Lambda Factor	Lambda Factor	Bin. Bits	Bin. Bits		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME					TIME					TIME
Marker	STAMP					STAMP					STAMP	 /min	 %	 mbar	 mbar
						0.3	0.961	1	        	        	0	1480	39.8	970	970
						0.91	0.86	1	        	        	0.6	1520	62.4	970	990
						1.51	1.016	1	        	        	1.21	1280	68.4	1040	1020
						2.11	0.992	1	        	        	1.8	1600	64.7	970	1050
						2.72	0.984	1	        	        	2.4	2000	57.9	970	1060
						3.32	0.821	1	        	        	3.02	2400	70.7	1100	1090
						3.92	1.039	1	        	        	3.62	3000	81.2	1140	1210
						4.53	0.899	1	        	        	4.23	3520	66.9	970	1250
						5.13	0.914	1	        	        	4.82	3320	15	970	1100
						5.73	0.789	1	        	        	5.43	2880	63.2	970	1010
						6.34	0.977	1	        	        	6.04	2640	72.2	1070	1150
						6.94	1.023	1	        	        	6.64	2840	57.9	970	1180
						7.54	0.961	1	        	        	7.24	2960	44.4	970	1080
						8.15	0.984	1	        	        	7.85	3080	42.9	970	1050
						8.75	0.992	1	        	        	8.45	3120	24.1	970	1030
						9.35	1.008	1	        	        	9.05	3080	15.8	970	1000
						9.96	1.616	1	        	        	9.66	3000	15	970	990
						10.56	0.945	1	        	        	10.26	2920	15.8	970	990
						11.16	1.008	1	        	        	10.86	2920	21.1	970	980
						11.77	0.984	1	        	        	11.47	2880	24.1	970	980
						12.37	0.945	1	        	        	12.07	2920	33.8	970	970
						12.97	0.782	1	        	        	12.67	3040	57.9	970	1030
						13.58	0.836	1	        	        	13.28	3280	94.7	1300	1240
						14.18	1.008	1	        	        	13.88	3280	20.3	970	1220
						14.78	0.789	0.961	        	        	14.48	2960	101.5	2310	1090
						15.39	0.774	0.891	        	        	15.09	2720	150.4	2190	1550
						15.99	0.883	0.86	        	        	15.69	3080	191.7	2280	2340
						16.6	0.867	0.844	        	        	16.29	3520	191.7	2300	2230
						17.2	0.828	0.844	        	        	16.9	3960	191.7	2320	2320
						17.8	0.821	0.836	        	        	17.5	4400	191.7	2330	2330
						18.41	0.844	0.836	        	        	18.1	4800	191.7	2310	2290
						19.01	0.828	0.836	        	        	18.71	5240	191.7	2270	2260
						19.61	0.828	0.836	        	        	19.31	5520	191.7	2260	2190
						20.22	0.828	0.836	        	        	19.91	5880	191.7	2230	2090
						20.82	0.813	0.836	        	        	20.53	6160	189.5	2150	2070
						21.43	0.836	0.86	        	        	21.13	6440	181.2	2050	2080
						22.03	0.805	0.922	        	        	21.72	6320	14.3	970	1900
						22.63	0.813	0.938	        	        	22.33	5320	14.3	970	1140
						23.23	1.991	1.047	        	        	22.93	4600	14.3	970	1040
						23.83	1.991	1.047	        	        	23.52	3680	12.8	970	1010
						24.43	1.991	1.047	        	        	24.13	2840	15	970	1000
						25.03	1.991	1.047	        	        	24.73	2040	14.3	970	1000
						25.65	1.991	0.961	        	        	25.33	1360	15.8	970	990
						26.24	1.179	0.953	        	        	25.94	1160	15.8	970	980
						26.85	0.953	1	        	        	26.54	1000	17.3	970	970
so what do you guy's think?
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
just a note for future logs...its better to log 1 or 2 blocks rather than 3. Looking at the first log its only giving a reading every 0.9 secs which isn't the greatest but you can see the air flow looks spot on
harty190486
POWER!!!
Dec 29, 2008
349
staffordshire
Jake the amount of air seen is huge just like how mine was with that filter and set up on its a really good filter logs look good mate i made 225 gs so roughly the same give or take
