That's what I'm after zboyd cheers.
Ow the did a 1.8t version too! That's even better news! Do you know what year etc so I can find some European car sales etc
Some V6 specs for you:
Kerb weight: 1483kg
Displacement: NA 2.8 litre 2791 cc
Type: DOHC 24 Valve
Maximum power: 203.8PS (201.0 bhp) (149.9 kW) at 6200rpm
Maximum torque: 270.0Nm (199 ft·lb) at 3200 rpm
0-100km/h (60mph): 7.3s
Power-to-weight: 135.54bhp/ton
Engine location: Front
Engine alignment: Transverse
Drive: AWD
"In some countries, a León was available equipped with four-wheel drive, which is based on the same Haldex Traction multi-plate clutch as the Volkswagen Golf 4motion."
See this...
In Switzerland, there was another official version tuned by Abt Sportsline of the León called "SEAT León Cupra 4 Kompressor". This version had the same 4WD and 2.8 litre VR6 but with 206 kilowatts (280 PS; 276 bhp) and 323 newton metres (238 ft·lbf) of torque.
The torques seems a bit low at 238lb though.
You're right but 276bhp is quite high, more than an R32 anyway and it has 400cc less. There's a lack of info on the web about it so I have no idea what tweeks were made.
Leave the wheel, go for that 'cool' Euro DUB thing :D
You're right but 276lb/ft is quite high, more than an R32 anyway and it has 400cc less. There's a lack of info on the web about it so I have no idea what tweeks were made.
No i think i would do the conversion, i want to be able to see past anything i was overtaking which would be everything :cartman:
Just found normal V6 an 02 in Germany for 12,000 euro's=£10,500 60,000 km seems a bit steep to me.
Kompressor does imply a mechanically-driven supercharger, in VW's case usually the G-lader scroll supercharger. This thing had a particular name, attached by VW, when I first heard about it many years ago on the Scirocco - which I have to say looked incredibly desirable. Can't remember what they called it now though.
Phillc, its because cars are cheap in UK :)/ I mean cheaper in general than in EU.
This leon 4 V6 kompressor must have been a great car :)
