Map running high boost
charlie123ii
i have a revo stage 2 on my ibiza cupra, did a log on it last night with vagcom and its running maximum boost, i mean the absolute max the KO3s can do. is this normal for revo to have it set at such an unsafe boost? i didnt get the car mapped but considering ditching the map for a safer one.
any thoughts?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
REVO is adjustable..
turn it down ;)
you need SPS select unit or your local REVO dealer to do this.
and what boost is it running?
charlie123ii
hmm i'll look into it then. also, cant you turn the SAI off with a map??
charlie123ii
think im gonna ditch the revo for MRC then. also the WG on turbo has been fiddled with to hold boost longer. bodgery. lol
tarzan
cupra owner from norway
Mar 15, 2008
1,122
drammen norway
have 2520mb when i logged mine revo stage 2 on k03 turbo. 164g/s in a 3.gear pull B6T6 with hallman boostcontroler with the heavy spring
Code:
	Group A:	'002				Group B:	'115				Group C:	 Not Running
		RPM	Load	Inj. On Time	Mass Flow		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME					TIME					TIME
Marker	STAMP	 /min	%	 ms	 g/s	STAMP	 /min	%	 mbar	 mbar	STAMP
	0.99	1440	27.1	4.92	13.22	0.59	1400	16.5	1020	1050
	1.79	1560	88	11.48	29.83	1.39	1480	77.4	1640	1050
	2.59	1800	102.3	11.07	37.86	2.19	1680	95.5	1720	1230
	3.39	2080	126.3	13.53	55.72	2.99	1920	112	1830	1440
	4.19	2400	151.1	16.81	74.42	3.79	2200	139.1	1960	1730
	4.99	2800	178.9	20.5	101	4.59	2600	166.2	2070	2080
	5.79	3320	191.7	25.42	136.97	5.39	3040	191.7	2110	2450
	6.68	3880	191.7	25.42	147.11	6.28	3640	191.7	2120	2520
	7.59	4400	188	25.42	157	7.08	4160	191.7	2090	2390
	8.39	4840	177.4	24.6	162.53	7.99	4640	181.2	2000	2230
	9.19	5120	168.4	23.78	164.17	8.79	5000	174.4	1900	2050
	9.99	5440	157.1	22.55	161.67	9.59	5280	162.4	1860	1990
	10.79	5720	150.4	22.14	162.03	10.39	5560	153.4	1820	1930
9,335
South Wales
How do you know its running the max boost that turbo can run? High WG duty %? Could mean you have a boost leak?
Can you post the logs up?
