JamJay
California Bound
Hi all. My car has thrown it's 1st fault up (touch wood no more :D) and I don't know what it means exactly, can anyone help?
1 Fault Found:
00931 - Locking Module for Central Locking: Rear Right (F223)
27-10 - Implausible Signal - Intermittent
Occasionally, when I park my car at night, the alarm goes off for no reason what so ever, stops and then doesn't do it again for days. Could this be the problem and if so, what the heck is it that needs replacing?
Sounds like it could be your problem. The lock is not always locking or getting stuck from reading the other threads that have been on here try using some WD40 on it but deffo points to the alarm going off.
It seems to do it when we get a really cold night and everything freezes. It's been raining for 4days now and nothing, the car hasn't moved since Sunday night as usual. The fault code is cleared so i'll try some lube in there and see if it's cured or comes back. Thanks :)
Yeah its most likely the cold weather m8 so hopefully lube will fix it let us know what lube you used too. [B)]
