Drivers side wiper not working.
Viking
Insurance co's are crap.
May 19, 2007
2,317
Near Richmond, North Yorks
Anyone had a problem with the drivers side wiper nowt working? Mine just packed up, and rather than dashing off to buy a motor it'd be nice to know that's what it is first.
VCDS scan gives fault code as
00154 - Windshield wiper motor - Passenger side (v217)
004 - No signal / communication.
I presume the passenger side is because it presumes the vehicle is left hand drive.
Any thoughts?
Viking
May 19, 2007
2,317
Master motor (on the passenger side in the Altea) controls the slave motor (on the drivers side).
12volts constant supply goes to both motors, and they're fused separately. When you put the wipers on the ecu sends an activation signal down a separate wire to the master (passenger side) motor, then the master sends a signal to the slave (drivers) motor via a second wire. The signal wire tells the motors to work (in turn) and the motors use the supplied 12v feed to drive them.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Cheers! Curiosity satisfied. :cartman:
Nov 13, 2023
I have the same error and my right wiper motor does not work, how did you fix it?
