Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
Right just got one of these
Fitted it and it doesn't sound much different unless i'm doing something wrong.
Just wondered any guide on setting up?
I have been turning and turning, got to the point where it started stalling but the sound doesn't seem very different to the 007P
Any ideas?
tried both but more driving around
I have just tightened it all way up now cos it was annoying me
But how should it sound? And to keep driving and doing turns will take forever to setup
have you got it so the trumpet is facing the bulk head?. i was having simular probs last week with mine as it was stalling when i reversed up my drive and was making the fluttering noise as i had put the dv on the wrong way and screwed it to hard and just turned it 1/4 turn at a time had it set up in 10 mins
Least your getting a noise lol
The trumpet is on the opposite to the inlet that goes into the TIP
Might try turning it around.....
Give Myki Da Pyki a shout or search his threads as Im sure he used to run one of these and say they are great once setup correctly.
this is the way it should be facing if it helps mate
Yeah i got it the right way just need to adjust it so its right but that will take me a lifetime and no doubt a full tank of petrol with all the stopping and starting
Defo right way around in the picture as i tried mine the other way and it started making the chatter
Maybe I will try to relocate it to the cold side and see if that makes any difference
No cos the bit that goes into the TIP is opposite the trumpet
So as your relocated yours the flexi bit goes back to your TIP
In other words looks right to me
