Can I get a bit of advice on this issue? In the autumn I noticed my car was steaming up and having found this thread concluded it was the door seals. So I took the car to a local
garage to get all 4 doors done. Long story short (and 3 trips to the
garage later) I thought the
problem was solved. It wasn't. So a month or so ago I took the car to Seat who did the front 2 doors (at a cost of £185
) and voila, much better! I was told that the original
garage had simply put silicone sealant over the existing foam rather than removing the foam.
Anyway, last week when we had some heavy rain my car was steaming up again. I noticed my front driver side sill was wet (passenger side bone dry), but no water on the inner plastic trim and when I phoned Seat they said its only a
problem when it comes over the plastic. Fair enough I thought, I will do a DIY job on the rears as they must be the
problem and I should probably replace the 1st garages siliconed-foam! The
problem though is that I cannot re-create the leak on any of the doors and there is so much water on the front driver-side sill that I'm finding it hard to believe that that is not the
problem!
At the weekend I pulled the rear carpets back to dry up what water was there, and while the passenger side was damp in the rear, the driver side was much worse.
Some pics taken a few mins ago:
Driver Side Front
Passenger Front
Driver Side Rear
Passenger Rear
What do you all think? From looking at these I think the driver-side front and passenger side rear need re-doing. I don't want to take it back to Seat unnecessarily as its a royal pain the backside to get there, but if the seal they "fixed" is leaking, I want it re-done!
EDIT:
Pics don't seemt to be working so trying again
