Get the diamond cut dude! If not then I vote red!
Champagne gold ftw. with black bolts!
right, more updates!
new Forge 007p:
slightly better air filter. lol!
AAAAAAAAADAAAAAAAAAAAAPTEEEEEEEEEEERS!!!!!!!!!
This badboy turned up from the land of corndogs and twinkies!
old engine mounts vs new ones!
from this:
to this:
in position(underside of front mount):
[B)]
Are they the turquoise ones from mateys mk3? Lol actually look good Alex! Noticed much difference with the drilled discs? I have pagid pads and think they're awsome. We should get a photo shoot going on sometime!!
looks mint like if you dont mind me asking how much did the refurb cost?
yea i meant the wheels and cheers mate was thinking of getting mine done but i might be getting rid in a few month so may just leave it
yes we should!
disks dont fade as much, pads were £20 for the fronts!
found out today that this has physically been chipped, so will need another ecu if i go IHI...
Mine was the same but mappers can flash your ecu back to standard then put a new map on it
did the N249 bypass today, fixed the random boost issue! POWEEEEEEERRRRRRRR!!!!!!!! :lol:
everything goes straight through to the road now, car is a proper beast!
drawn up a list of things to do:
Cupra To-Do List:
Pro Detail
Find out where the boost has gone DONE!
Bypass N275 & remove SAI & N112 (50% done)
Finish & Fit Jap Wheels
New Coilies?
New Pads all round
Cupra Shopping list:
312mm Brakes - next big purchase.
FMIC & Pipes (50% done)
Harnesses
More bodywork
Selector tower
Short-Shift kit
Clutch
Lightened Flywheel
IHI manifold
IHI turbo
Oil lines
Turbo to tip exhaust
Injectors
Map
TIP
CV joints?
Bottom-end rebuild?
gave it a rinse to get some grime off, it will be getting a pro detail at some point.
then chose one of these colours for the PIAA centres:
then this turned up:
tried using this on the back barrels, wouldnt touch all the burnt-on brake dust!:
so resorted to the "drill of doom" with a scotchbrite wheel attachment:
:smoke:
Are they guna get on the car anytime soon! look good tho bud.
After 'owning' you on the roundabout the other day :whistle: it makes me miss mine sooo bad! Was looking hard dude, will look amazing with the rimz on!
I'm in two minds weather to buy one again. It's a love-hate thing with the vario at the mo, but not getting an amazing amount of miles more out the tank than the cupra like I thought I was!
mate i like were this is going??
plus have you smoothed off the front number plate bit?? that looks mint!!
coming along mate good work..
thanks!
mate, its defo a love/hate thing with these. the N249 didnt fix the boost for long, now i have mega-lag and nothing more than 10psi till 4.5k???? [:@]
yeah, was done a week before edition last year, next on bodywork is rear plate recess shortened, and middle bar of the front bumper removed, and sorted out to look OE.
