DUB BOY
119
London
Any ideas as im about to do an oil and sump change, but its plastic is there a special tool for this as i dont want to damage it
Thanks Sam
sorry yh the cap. What is the tool called or where can i get it from if you have any pics it would be great.
Thanks Sam
I did the same, used a monkey wrench and it cracked, so I had to pay £16 for a new one. And then buy the proper tool anyway!
I got mine from Ebay, for my car it was just a really big flat socket but i don't know what your car needs. It doesn't need to be an expensive version as it doesn't have to do much, I think mine was made by Laser?
The cupra r has a metal oil filter not a plastic covered paper one so that tool wont work, the bottom one on the halfords website would be a better option providing it has the right amount of slots in.
It tends to be 1/2inch for the genuine tool and 3/8inch for the aftermarket stuff.
Ah that sounds right. All I remember is having to hunt all round town to downsize as I only had a 1/2 inch on me!
EDIT: Whoever says 'That's what she said' about my half inch comment is getting a slap... :D
cheers for the help guys, i found one at work which luckily enough was the right size just wipped the sump of and the filter im bloody filthy.
Yeah, I have to admit I do prefer cars where you replace the full oil filter rather than just the element. It really is a messy job to replace the element! :censored:
brought on them laser cup wrench then one of these, http://www.mailspeedmarine.com/tools-repair-kits-fixings/pela/oil-extractor-pump1004535.bhtml never done my own oil change before, wish i had got these ages ago, would of saved me £££:)
Have you used the pella pump with no problems? I have been toying with getting one for ages, but I read somewhere that the dipstick tube on the tdi150's has some sort of gate that shreds the tube on the pella when you try to pull it back out?
For the oil filter cap removal I put a rag over the plastic bit and then use a chain wrench tool
Messy, but just hammer a screwdriver all the way through, then turn. Job done.
LMAO That's funny!
Seriously, though, it works - done it every time I've done one, not had too many problems.... except when the screwdriver wasn't long enough to make it through to the other side so kept slipping - hammered it through another bit of the thing and it was fine.
I think you can get chain type tools which fit round the filter and grip on it (uses bikechain). Don't know how well they work though!
Whatever you do, don't take the advice of hammering a screwdriver through and using it as a lever to remove the oil filter.
The TDI engine has a solid filter housing with a plastic cap on. Removing the cap gives access to the drop in type paper element filter, and when removed the new one drops in place, then the filter cap is replaced.
DUB BOY appears to own a Mk1 Golf, so what he's asking on here for I have no idea.
ANYway, as Viking says, the TDI engines use a paper filter element inside a fixed housing with a plastic cap. Hammer a screwdriver through that and it's expensive. And it won't help you get the cap off in any case.
The cup wrench tools that fit the filter cap on the TDI also fit the flats on the metal can-type replaceable filters you find on other engines, so it isn't a bad investment. I'd only ever use a screwdriver as a last resort, as it's irreversible - if the filter doesn't come off you can't drive the car. Also, some cars have a feed tube attached to the filter mount that goes down inside the filter can. Hammering a screwdriver through the filter is liable to damage them.
My old Ibiza used a 35mm socket to remove the filter cap. I think the Toledo is the same.
Torques back to 25Nm IIRC. Not too tight, or it will snap! Its the o ring that does the sealing rather than the cap.
Its a very, very easy filter to change.
Conks
