that must do your nut in is it noticeable when outside the car?
Right.
This is the knocking noise: http://www.vimeo.com/11147816
This was taken when in 1st gear rolling off clucth/brake etc... This is now a constant feature everytime in get in the bloody car! Annoying thing is nobody knows what it is! It isn't effecting the car either!
Right.
That noise is crazy! Were you driving over uneven ground? Are your ARB bush end stops still attached?
JESUS! I think one way of looking into it could be to get the front wheels off the ground (put it on axle stands, take the wheels off) put it in first, let it run and lie underneath it and see if you can hear more precisely where it's coming from...
That way you could put your hand on the gearbox/bottom of engine/driveshaft and feel if it is coming from any of these. - Obviously being carefull how you do this - I would wear "mechanics glove" in case I touch anything hot, also making sure I didn't put my hand anywhere that could potentially catch my fingers. I done this with my Clio and foud it was the CV joint as the rubber boot was intact it didn't have the appearance of being buggered.
.G.
