No mine is from Turbo DynamicsIan on here is also running the same turbo, both of which share the same aggressive characterics that the CR hybrid lacked ever so slightly, imo of course. Bill/Badger 5 has mapped both variants
Also bear in mind the list of mods I'm running to achieve this power figure, i.e. rods, water methanol injection etc
Others have done hybrids cheaper, though mine was built for maximum possible power from this setup and equally as important; reliability
Turbo Dynamics MD445 (JBS04) - see my thread for details
I've been out in a CRT hybrid too and glad I went with TD
Not to give the company too much bad feed back. Basically they give you a year warrenty on all turbos I gave them a ko3 to be converted to k03s.
Got the turbo back off them and the shaft dident seem to spin so freely on my new turbo got it fitted by a garage did everything that it said on thier warrenty. And 6miles down the road the turbo blew up. Took the turbo back along with warrenty and garage number.
They pointed the blame at me and I had to fork out the cash to rebuild the turbo again. I'm not saying i wasent totaly to blame. I just wouldent trust thier warrenty. It's a con in my opinion.
Don't get too hung up on my rolling road results guys - dyno lottery still applies.
I can only gauge my figures against other cars I've come across which does seem to put me in that ball park. To give you a rough idea, new RS4s are easy pickings.
The TD units just seem more "lively" than the CR counterparts but that's my own opinion - bear in mind different remaps etc will also contribute as I asked Bill to make mine as aggressive as possible - plus with rods it could really be let loose without worry. There's a lot to be said for peace of mind, though it comes at a price. If you look at my RR printout you can see how the torque is very spiky as it gets thrown in very low down the rev range, accounting for the aggression, The CRT I went out in seemed much more progressive. At the end of the day though they're both still small turbos that will only flow x amount so we're not talking about day and night differences here.
I was lucky that I managed to source my hybrid from a user on the forum selling one unused for a fraction of the price TD want if you go direct.
Prebs said:Thanks for sharing! I´m considering the cr-hybrid as these are on exhange basis and will turn out a lot cheaper then £1100. I´ve sourced all the other parts needed just turbo left. I´m still on the forge fmic and as we all know the pipework on these are far from optimal but I guess it will cope with the cr hybrid setup in the end.
If I get to choose from the top shelf I would go for the TD yes with similar agressive map as yours, getting a real "sleeper" on the road but there´s a big difference in costs(rods/turbo) between yours and running a cr-hybrid setup. As you say there wont be a huuuge difference in preformance but still very noticeble.
How often do you need to refill your wmi tank?
Prebs
Prebs
