Sam on your picture where the 2 green arrows are which you say leave unblocked, is that a t piece you have on the top one but just not blocked it off, also whay do people say you need to plus both of them?
like this but
i have mine like this now
maybe i should invest ia oo7 1st then do the bypass. how easy is a 007 to fit and does it require any special setting up?
take old one out put new one in ;) two pipes mate really easy to do and you will wirk it out as soon as you look at it
007 is easy as pie mate and nope its all set up ready to fit
all you got to do is take the two old clips off prob with pliers and replace where old one was (buy 2x jubilee clips mate) tighten those up and bobs your tea pot ;)
thats the spirit mate ;)
Just dont pull the grey box off or leave it unplugged you will get an error code
i know i know sam im bk tho to annoy scn :D :D
sounds easy enough will be on the look out for one then always had the impression it was a fiddly job hence why i havent done it sooner. had a few turbo cars but this is my 1st vag. so not quite used to the bits and bobs yet
there about £80 on eBay mate best to get a silicone hose kit for it aswell always a good investment
naaa gaz it quite easy once you do it you will be like bloody hell what was i worried of :)
and i think awesome on here do a good deal on them give them ago or try forge use discount SC10 for 10% off
and mike yep it will all explain its self once you bypass then if you look at the old stuff its doing nothing hence take it out and wheres bout in norfolk are you mate
