twistandgo
Well... its finally happened.
After 28,000 trouble free miles... the dpf light has come on.
Started with an intermittent emissions warning light which has been off for ages... the came on again the other day. So I booked car in for service. Then yesterday the DPF light came on. Tried the regen driving as per manufacturers instructions in manual.. but hasnt gone out. Wife driving to work this morning and said it went in to limp mode with the coil light now also flashing. Engine fault, go see dealer.
So... pulled over,....AA called and got the emissions light off. DPF and coil light still flashing. Towed to dealership.
Now.. after A LOT of research in the TDI section... I reckon... the intermittent fault of the emssions light has meant that a sensor was on its way out. It literally "went" yesterday and didnt clear as per the norm... this has resulted in no regen going on with the car and has capped out on DPF emissions...OR.... Both sensors have failed and has gone in to limp mode as a result thinking that it has a blocked filter.
The car is used regularly.. the wife has a fairly heavy right foot under acceleration but can drive economically when she wants to and it gets used on A and B roads with a good variation of driving. 28,000 miles with no issues until now so....
Thoughts on a postcard?... I reckon its a sensor or sensors that are to blame...
Anyone else any ideas? does it sound fair enough?
Car is a September 57 plate and so is still under warranty.
