1 - pressure plate
2 - friction plate
3 - kit assy (as genuine)
4 - plate washer for pressure pate to flywheel
5 - crankshaft bolts
6 - thrust plate
7 - thrust plate spring
8 - pressure plate > flywheel bolts
9 - inspection cap (green VWlogo) levers off
10 - thrust bearing
11 - radial shaft / cable arm
12 - splined release arm (common to break or strip splines)
13 - securing clip for release arm
14 - return spring for release arm
15 - stop buffer
16 - seal for radial shaft
17 - push rod (common for pushing through thrust plate #6)
19 - balance weight
in short with pedal pressed down (ish)
cable pulls #11 upwards
#11 twists #12 inwards
presses against #10
pushing #17 inwards
against #6
releasing pressure off #1
releasing #2 for clutch engaged
common faults
#12 bends/breaks/strips splines easily checked by lifting off #9 and inspecting it under operation
#6 breaks open letting #17 burst through it
either way press pedal down - no clutch or to start seems harder to get in gear - similar to pedal box symptoms too
020 Clutch...
Sachs clutch kit from Euro Car Parts actually contains
1 - pressure plate
2 - friction plate
6 - thrust plate
MAY SPEAK TO YOU AGAIN, THANKS FOR YOUR ![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
