well thats me got the LCR back and my bank balance is significantly worse off
all the work carried out by GI Motorsport was as follows:
new clutch master cylinder
new clutch slave cylinder
new clutch position switch
sachs engineering race clutch
jabbasport lightened SMF
quaife ATB diff with bolt fitting kit
i tell you something. all this car wants to do is rev now! she picks up so quickly now through the gears.
slow pull aways are a bit jerky, you really need to rev the car on initial pull away. the clutch is designed for harsh fast road / track / 1/4mile use so will be interesting once i get used to the new clutches characteristics. yet to really test the diff out as yet due to the icy and damp conditions this morning. trust me to have the damn thing fitted as we come into the weather lol
Gaz at GI told me than when the box arrived with all the bits in it from jabba he though there was bits missing, cause the total weight of the clutch, flywheel, slave cylinder, diff and fitting kit weighted in at less than the stock DMF
so the amount of weight i've save as well was quite impressive
