vagcom cable
Crafoo
Crazy Fool!
Apr 30, 2005
5,498
At home
You might find you won't get much in the way of sympathy mate, the general feeling may well be one of "you bought a cheap cable and it doesn't work...tough"
what is the problem?
PS. you might have been better posting this in the Vag-Com section, people browsing there might be able to help you more.
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
What doesn't work? Have you installed the drivers, then plugged in the lead? Then checked in device manager which com port the lead is assigned to. Then in vag-com gone to options and selected the correct port and clicked test?
alexbradford
289
paisley
I tried different versions of the software, Including vag-tacho with windows 7 and couldnt get any of them to work.
If you go in the vag-com section in here you will find most people have problems with windows 7 and vista
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
With your cable plugged in Go to start menu type device manager in the search bar and hit enter now go to ports, com & lpt. Now open that and see what com port your lead is showing up as. Let us know what it says.
chris_200120vt
MR carbon fibre
Oct 4, 2008
2,711
YEADON, LEEDS
done as you have m1keh it comes up with the following:-
globetrotter gi515m application interface com22
globetrotter gi515m diagnostics interface com21
when i click on either one the status say device is not working properly :confused:
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Do they dissapear if you remove the lead? If they do then replug it in and update the drivers but tell it to use the ones from the cd you got with the lead.
chris_200120vt
MR carbon fibre
Oct 4, 2008
2,711
YEADON, LEEDS
just tried it again no look the globetrotter gi515m application interface com22 and
globetrotter gi515m diagnostics interface com21 stay on whether in cable is plugged in or not plus when i connect the cable to my laptop makes a different noise so im now thinking the cable is at fault
chris_200120vt
MR carbon fibre
Oct 4, 2008
2,711
YEADON, LEEDS
well ive had a word with the seller to which they where no help at all:w4nk: so i have gone and ordered one from a diffrent seller. also i have noticed that my hand held code reader does not have pins in every hole where as the usb cable does
