dannyboi321
dannyboi
Jan 7, 2011
628
crawley west sussex
hey all have recently fitted a uni front mount intercooler and induction kit to my mk 3 ibiza cupra and seems slower than it was before :/....
iv put normal intercooler pipe clips on, not the higher pressure ones would it make a difference if i put the high pressure ones on ? maby its leaking boost slightly ?
also this might be correct but will ask neways mines got a stage 1 revo map and boosts at 10psi in 1st and 2nd then 15psi in 3rd and 4th then 16psi in 5th ? does this sound right ?
any help would be great many thank dan :D
Have you logged the car to see what figures its producing on the MAF,timing pull and boost?
15psi is just over a bar, my Cupra will produce 18-20psi spike in every gear then tail off so I would say investigate for any leaks and log the car.
defo a leak, a revo map is generally quite aggressive so to be pulling 10 psi on boost you need to be checking pipes mate, my leon is stage 1 and i spike at 21 psi, holds at around 18 for a while then starts tailing off towards the redline
depends what boost and timing setting it was set up with , not all revo stage1 maps are hitting 20psi, mine was set up with boost 6 timing 4 , which was hitting 15 psi and holding at 13 psi , cause i specified i wanted a smoother progressive map, i think boost 9 timing five , will hit 20 psi. but i would get the it check for boost leaks mate
hello, have u found out what was the problem? i am having the same problem..no boost spike as before, only aroud 11 psi of boost, car is slow...
Make sure you check all the silicone. I bought the uni kit from ebay and mines was running sluggish. Turns out one of the "brand new" silicone pipes had a split in it!
ecu??
hi daniboi, what was at fault for your ecu repair? or replacement? and how did you cure the problem? thanks @ sorry i posted on a subject.
