nother little update for 2011
needed a new tyre as mine looked like this
10 points for make and model of tire
and it changed to this
this bit was fubared
reason
some other things that happned in the process(along with 2 bent spanners and 3 other ratchets fubared (only cheapies tho so))
also its booked in at black circles to get another new tyre unfortunatly they dont do A539s but meh ill live its better then Nankang [B)] yoko Sdrive
oh also will be running some 5mm rear spacers after tuesday :) and should be lower soon :)
The old tyre was a Toyo T1-R
The new tyre is a Yokohama, but not 100% on model, had 1 on my RM's, was good, possibly S-Drive, don't think its a Parada, as that has different shape, so going for s-drive?
just another little update:
ordered a set if these
anyone used em!?
oh and suj there A539 Yokohamas like the paradas i am having an S drive put on driver side
tiny update got one of these on the front aswell now
and tracking sorted and while it was on the ramps replaced all the clamps on the zaurst and got rid of the heatshield on the back box NO MORE RATTLE!!! :funk::funk:
Mental! :happy:
Atleast your setups correct, thats good even wear.
the joys of getting my tracking done!
i got it done yestaday it had 10 defgrees of toe in on that tyre :O where i twated a kerb with the wheels in the ice,:ban: as a bus was comng the other way [:@]
shane will try my hardest to get the suspention sorted! i need to get some wheel spacers aswell to get the stance right[B)]
anyone used em!?
ok my guy has ****ed me about :mad:
needed cheering up so bought one of these
also it blocks out my rear wheel bearing whine :D i hope :whistle::whistle:
EDIT
there is no hoping it is infact keeping all engine noise/extirior/intirior/talking between pilot(me) and co-pilot to a minimum (between tunes or in the "quiet bits") :D
little edit my sub even came with a port plug(i affectionately call it the but plug) and it deffo stays in at all times for that nice punch you in the back bass! :)
all the exhaust heat shields are off so no more rattling :D HEAVEN!!!!!!!! and a cunit to take off especially not using a jack just did it on the floor :) also rear section of exhaust was loose so that got a tighten up!
ok nother update, port and polished throttle body is on the car along with an oil change :)
another update
got a lower front strut brace today :) feels better out of corners :)
and re-done all my vacuum lines with orange samco hose :)
i know its gehtto but its better then what was there before which was nothing just a hose hanging down!
and the vacum lines are 4mm samco :) 5 quid rally design
