phunkymonkey
hi peeps
just logged my lc and just wanted to confirm its stock before i get a remap?
here is the log i done in 4th
Code:
Group A:,'115,,,,Group B:,'003,,,,Group C:, Not Running
,,Engine Speed,Engine Load,Charge Pressure,Charge Pressure,,Engine Speed,Intake Air Mass,Throttle Drive,Ignition,,,,,
,TIME,,,(specified Value),(actual Value),TIME,,,Angle Sensor 1,Timing Angle,TIME,,,,
Marker STAMP  /min %  mbar  mbar STAMP  /min  g/s %, °BTDC STAMP
0.40 2400 87.2 1710.0 1190.0 0.01 2360 20.67 12.5 24.0
1.22 2560 122.1 1710.0 1640.0 0.82 2480 55.39 100.0 13.5
2.11 2800 128.6 1690.0 1710.0 1.62 2680 65.64 100.0 9.0
3.02 3040 130.1 1690.0 1720.0 2.53 2920 72.94 100.0 10.5
3.82 3280 130.8 1660.0 1690.0 3.44 3160 78.06 100.0 13.5
4.64 3480 130.8 1630 0 1650.0 4.22 3400 84.78 100.0 12.0
5.53 3720 126.3 1640.0 1630.0 5.04 3600 87.22 100.0 15.0
6.45 3920 127.1 1670.0 1650.0 6.05 3840 93.17 100.0 12.8
7.26 4120 127.8 1670.0 1680.0 6.85 4040 97.69 100.0 15.0
8.16 4320 128.6 1670.0 1670.0 7.76 4240 103.97 100.0 18.0
8.96 4520 128.6 1670.0 1660.0 8.56 4440 110.89 100.0 12.8
9.77 4680 130.1 1670.0 1670.0 9.36 4600 112.67 100.0 15.0
10.57 4840 130.8 1670.0 1660.0 10.16 4760 116.28 100.0 18.0
11.37 5000 130.1 1670.0 1650.0 10.97 4960 121.78 100.0 14.3
12.27 5160 131.6 1690.0 1660.0 11.77 5080 127.86 100.0 16.5
13.18 5320 133.8 1700.0 1670.0 12.69 5280 133.56 100.0 13.5
14.09 5480 134.6 1720.0 1680.0 13.60 5400 138.53 100.0 15.0
14.99 5640 134.6 1700.0 1690.0 14.49 5560 144.06 100.0 15.0
15.80 5760 133.8 1670.0 1660.0 15.40 5720 146.56 100.0 18.0
16.72 5920 132.3 1640.0 1630.0 16.20 5800 147.44 99.6 18.0
17.61 6000 128.6 1620.0 1610.0 17.20 5960 149.44 100.0 19.5
sorry for the way the log has come out!!lol i dont have exel on this pc!
Judging by the air mass readings, it works out at roughly 186 bhp, so I would say it is a standard map, or a really poor remap.
your mass air flow rate is 149gs, this is around 186bhp give or take. i would say no its a standard map.
lol the whole car is stock, not even a aftermarket radio! so i figured it would be , just wanted to make sure!!lol
cheers
yes if im corect your g/s reading at its highest was 149 witch = 186 bhp ;) all good imo unless its not suposed to be standard? lol
thanks for your advice peeps!! mow to bolt on some goodie and get it mapped.
For future reference guys - the more accurate way to determine if mapped or not is to look at the requested boost, rather than air flow....
Yeah I kow but he hasn't postes those log. The only pressure rating is (i presume) ambient, which works out as 25 psi near enough :O
Erm
He's posted Requested & Actual Boost.
And ambient pressure is 1Bar, so remove 1000mBar from the figures to give you your 'boost'
was going to say same thing , was told by R **** the way to judge standard map or remap car requested boost , cause if the car as a fault , airflow (g/s) and or actual boost might being lower than request
thanks guys, now happy that its is standard! and also now i no how to work out my boost!!lol
cheers again
Just out of interest then, what would you genrally expect the requested boost to be on a stock and also a Stage 1 mapped LCR? Would just be nice to know, as I'm also in the is it isnt it boat about wondering if mine is mapped. I have a RR printout from AMD and it seems mapped but just be good to know, so I can then compare to some logs.
