Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
right guys need to pick your brains here as we are at a loss
the new engine is in but it turns but wont fire any ideas ?
so far stu has changed everything off my engine to the other one including coil pack ,
any one local with a dyno ? any help greatfully receaved
well its deffinatley getting fuel to the fuel rail
You using your original ecu, immobiliser box and chip kez?
Coil Pack, Crank sensor?
i still think immobiliser problem lol
deffinitely immobiliser related...
try as a temporary fix, shorting the fuel pump so its got a constant ground and a constant live and then crank it, itll start and run then to confirm its the immobiliser system
id say immoboliser since its all been out disconnected and the rest of it.
i have a snap on solus fault code reader, however i dont know how much it will tell you, and im down Reading until Friday. :/
Having a scorpion alarm / immobilizer on mine, mine sometimes doesn't cancel properly, and switch itself off, thus not switching on the fuel pump, so it starts, then cuts out. Most definitely the immob!
