Guest - you can now get 20% off all AutoBrite detailing products!
Exclusive SCN members only discount thanks to APAutostyling
check the engines getting fuel?right guys need to pick your brains here as we are at a loss
the new engine is in but it turns but wont fire any ideas ?
so far stu has changed everything off my engine to the other one including coil pack ,
any one local with a dyno ? any help greatfully receaved
they both on the right way round ?well its deffinatley getting fuel to the fuel rail
yes mateYou using your original ecu, immobiliser box and chip kez?
midlands vw kindley leant us a coil pack to try but it made no difference , we thought the crank sensor mate at first when it would turn but not fire but now it is firing but dying so maybe not that ?Coil Pack, Crank sensor?
i still think immobiliser problem lol
anything is worth a trydeffinitely immobiliser related...
try as a temporary fix, shorting the fuel pump so its got a constant ground and a constant live and then crank it, itll start and run then to confirm its the immobiliser system
my causin came down with his code reader but it wouldnt let him into the engine part , something to do with because the engine hasnt run there is nothing to readid say immoboliser since its all been out disconnected and the rest of it.
i have a snap on solus fault code reader, however i dont know how much it will tell you, and im down Reading until Friday. :/
the problem now is mids vw cant get her in untill next saturdayHaving a scorpion alarm / immobilizer on mine, mine sometimes doesn't cancel properly, and switch itself off, thus not switching on the fuel pump, so it starts, then cuts out. Most definitely the immob!
