abf turning but wont fire
Aug 22, 2008
3,221
cannock
right guys need to pick your brains here as we are at a loss
the new engine is in but it turns but wont fire any ideas ?
so far stu has changed everything off my engine to the other one including coil pack ,
any one local with a dyno ? any help greatfully receaved
Big-Pete
Always on the Limit
Aug 8, 2010
3,032
check the engines getting fuel?
Aug 22, 2008
3,221
cannock
that was the first thnig he checked and double checked mate , no there are fine but there doesnt seem to be any spark , just tried easy start but that didnt work
Aug 22, 2008
3,221
cannock
the immobiliser is te origional off my car we have tried the one off the doner car with its chip and it is doing exactly the same
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
id say immoboliser since its all been out disconnected and the rest of it.
i have a snap on solus fault code reader, however i dont know how much it will tell you, and im down Reading until Friday. :/
LMJ
Previously CEY_CLS :-)
May 4, 2009
1,789
Bangor, North Wales
Having a scorpion alarm / immobilizer on mine, mine sometimes doesn't cancel properly, and switch itself off, thus not switching on the fuel pump, so it starts, then cuts out. Most definitely the immob!
Aug 22, 2008
3,221
cannock
You using your original ecu, immobiliser box and chip kez?
yes mate
Coil Pack, Crank sensor?
midlands vw kindley leant us a coil pack to try but it made no difference , we thought the crank sensor mate at first when it would turn but not fire but now it is firing but dying so maybe not that ?
i still think immobiliser problem lol
deffinitely immobiliser related...
try as a temporary fix, shorting the fuel pump so its got a constant ground and a constant live and then crank it, itll start and run then to confirm its the immobiliser system
anything is worth a try
my causin came down with his code reader but it wouldnt let him into the engine part , something to do with because the engine hasnt run there is nothing to read :confused: but if u are availabe after you get back anything is worth a try mate
the problem now is mids vw cant get her in untill next saturday :(
cheers for all te help guys this is going to be something daft i just know it :lol:
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
Can you not take the crank sensor off your old engine, put on this engine, see if it does the trick.
Worth a try I guess?
