fourtwofive ibiza daily project
Jul 4, 2007
1,674
bristol
Update but just a small on got my charge pipe welded for a bottle of wine o it's great knowing a 55 year old aluminium ship builder :) legend!
Jul 4, 2007
1,674
bristol
just testing the water with a 3inch intake idea its not a proper 3inch but i think its possably going to flow more than the forge one i currently own. as it seems to bottle neck very high up.
here is some rubbish pictures but you get the idea its a bit thown together at the moment but if it works i will build a good looking one thoughts welcome poeple. got to order a few bits and get some welding done.
in the making
Apr 15, 2009
2,189
Midlands
Looking good similar to the tip i have on mine which i got from joehirth
51mm 90 degree off the inlet then just after the water pipe it ups to 63mm (2.5") all the way to the
Apr 15, 2009
2,189
Midlands
In all honesty i didnt feel any performance difference at all, BUT it did feel alot smoother on boost believe it or not, louder spool too.
Im just struggling to keep the hose on the turbo lol it keeps slowly slipping off and its clamped down so tight too, quite wierd as its a tighter fit on the inlet than the forge was and that never slipped once even without a jubilee on it.
Jul 4, 2007
1,674
bristol
my forge one keeps slipping also got the new one cranked up hope it stays on the only difference is mine goes 3inch straight after water lines. we will see going to log before and after.
also i think it will look 100 times better
Apr 15, 2009
2,189
Midlands
They do look alot neater imo, its crap fitting the tip to k03 turbos, the jubilee starts slipping as your doing it up lol
Logs will defo be interesting to see
Jul 4, 2007
1,674
bristol
Tell me about it mate pain in the ass or what I was outside today raining, under the car pushing the jubilie clip hard against the turbo the trick is I recon if you can fit a socket on the jubilie it's not far enough on I always had to do it up with a huge extended flat head screw driver. God I'm sad but it's on :)
Best get a top loads garret gt30 to avoid this under the car issue hay.
Mines pushing 211g/s at the moment so hope that goes up a tad we will see
