Painting Brake Callipers
figolovechild
Leon FR CR 170TDI
Sep 12, 2011
190
Glenrothes
Hi folks,
Has anyone painted their brake callipers on the Ibiza Cupra DSG. I have a white Cupra and
thought painting the callipers black would look quite good. If any of you have done it what paint do you suggest using which will last the longest and look the best. A glossy finish is the look I would be hoping for. I take it the brake pads need to come off before painting?
Any advice you guys have will be brilliant guys.
Adam
cupra-ads
471
Colchester, Essex
i have white cupra with black calipers... they look very good! i'll see if i can find a pic and i didnt worry about the pads. cos they are black already i just painted them aswell lol
Lamont
72
North Ayrshire
I have a black Ibiza and was thinking about spraying mine a glossy black.
Would I need to dismantle the brakes or leave them on the car and just paper round them.
Jun 17, 2011
946
Grimsby/Birmingham
Got a yellow cupra with yellow on calipers...sprayed on but its so much easier if you painted it on...less hassle with the prep, and the best paint to use is hammerite
figolovechild
Leon FR CR 170TDI
Sep 12, 2011
190
Glenrothes
Nice one. Going to stick with the black. Thought I would have the hassle of having to dismantle it all to paint it but think it will be straight forward enough.
GazEP3
Missing the vtec yo :(
Nov 27, 2009
663
Northern Ireland
Wouldn't go to the effort of dismantling your brakes just to slap a bit of paint on them! Only if you were getting them coated professionally say at a owder coaters or something.
Tip: Put the first coat on thick and if you still have any brush lines left once thats tried and want a really smooth finish, keep a small tub of petrol to hand and dip the brush in it briefly before dipping it in the paint, this will water it down slightly and allow you to apply it that little bit smoother. Try n get your hands on a proper heatgun as opposed to just using a hairdryer.
figolovechild
Leon FR CR 170TDI
Sep 12, 2011
190
Glenrothes
Cheers Gaz
chicca1987
I've got a 5month old track grey 1.2tsi ibiza... was considering painting my calipers red... however someone suggested a dark purple (one of my favourite colours). Which do you think would be best?
chicca1987
admittedly... i like the look of red calipers... but i guess dark purple would be far more original....
i guess both red and dark purple match track grey... and if i try one and dont like the result i can easily change to the other colour :)
craig cupra
Drive it like u stole it!
Jul 13, 2010
81
essex
hi guys i was going to paint mine. did you do any prep work before hand ie clean the callipers before painting them. if so what did you use? thanks
5509433
949
7
Braintree, Essex
All I did was remove the rim, brush over with a wire brush and then started to paint. Check for paint drips if your using hammerite. Leave to dry for an hour and pop the wheel back on!
GazEP3
Nov 27, 2009
663
Northern Ireland
A wire brush would do the job but I went a step further and used one of those abrasive wheels on mine to try and smooth the surface a bit more and this ensured there was absolutely no dirt left too, looked like brand new brakes when I'd finished prepping them :D
