god there is some rubbish banded about on here.
the way i see it you took the car to them with an amber light on the dash? its been like this for some time? you seem un concerned by this amber light?
you drop it off reporting a sound from the right front wheel.. nothing else, no report of an oil issue. simply that there is a sound coming from the right wheel. As you say on here, 'im not stupid', and so i assume you are happy for the
garage to also think this of you. So they might think, well hes driving around with the oil light on but is adament its a wheel issue.
It might also be fair to say that when there are 'noises' coming from somewhere such as the suspension or wheels then a test drive is going to be needed. You have not said not to drive it or that you are concerned about the oil light.
However, the mechanic did see the light, and did check the oil which is an interesting point, it could be said be took appropriate action in checking there was enough oil, but i also see an arguement that this amber light warns of potential issues. However as many have said its not a pressure warning its just a low level warning, so if he has ensured there is enough oil in the car then this 'fault' has been confirmed as being ok?
maybe, maybe not.
A phone call to you at this point might have been a good idea, but i suggest few garages would be this pro-active.
Now, lets look at the damage and that they have taken it too a bumpy road..
we all know there is little clearance for the sump, - is your car lowered? if so then the car is quite suseptible to sump damage.
Potential for damage... bumpy road.... its doesnt take einstein to see the potential link here...
What i want to know is:
How does the damage to the sump look? are there marks suggesting a grounding? is the damage consistent with damage from outside in or inside out?
Where is this 'bumpy road'?
Id want to see this instantly, and then take some time to look for marks that might show a grounding or a perhaps even some marks with a line of oil starting from there!
I have sympathy, i do, but i also want to play devils advocate rather than just adding to the general theme of abusing the
garage.
However, from what i have read, it does indeed point to either:
1. that the amber light was on for a reason, possible oil starvation, perhaps blocked pick ups and its a simply engine failure (which could happen to anyone)
2. that they grounded the car when driving down the 'bumpy road' damaging the sump and losing oil leading to the damage.
It will be interesting once a new engine is fitted whether the sound you took it to the
garage for is still evident..........
PS cupra R ick's post before mine is one of the more sensible on here.
