delboyuk2005uk
377
St Helens
Put key in this morning says coolant is low.
So had a look and it's on the min line.
So where can I get coolant and from where I have halfords near by I can go after work.
Is there any special coolant I need for the tdi fr model?
Please advise?
Car is due a service so proll reason it's low?
There are several different types of antifreeze, depending on the age of the car.
G11 VW spec TL774C Blue/Green colour
G12 VW spec TL774D Red/Pink
G12+ VW spec TL774F Purple
G12+ can be mixed with G12 or G11.
G12 cannot be mixed with G11
Halfords Advanced Antifreeze is G12 equivalent
Comma XStream G40 is G12++ equivalent (TL774G)
Comma XStream G48 is G11 equivalent.
Depending on the colour of the antifreeze already in your car, I hope this helps you choose the right one.
Please advise?
I had this a month ago and the radiator was fooked....hope this isn't the case for you
There are certain types that can't be mixed, see the other guys post ;)
Mine is red pink colour.
Just put a bit of water in for now till I get halfords after work.
Before I put water in noticed the coolant was above the minimum line so does it expand after engine use?
Looks like VW have replaced G12+ with G12++.
The ETKA database shows 'coolant addative, plus (lilac) replaced by coolant addative, plus-plus, on 01.08.11'. No colour given for the replacement addative.
