I'm hoping your EGT's were properly measured at the head before turbo, so that you don't melt anything?
also i would liek to add people saying smoke is a bad map dont rly no wat ther talking about wat tdi that makes big power dosent smoke ?
Yeh he has! Imagine Sparky's car with 2x more smoke
Can I ask what mods your running BiGG? The reason I ask is my 140PD with a hybrid turbo, 3" s/s turbo back, EGR complete delete made 218BHP and nearly 350lbs of torque and mines doesn't smoke really at all.
hes ruuning standard just has the milltek dpf delete and pannel filter
btw wat boost are you running with that hybrid ?
max we can go on stock is aroudn the 25psi mark after that thers a risk of a blown turbo if we could get more boost ther would be less smoke
i agree it does smoke a lot
but wen ur in serch of more power to the extent biggaddicted was then smoke is the only option
he just wanted the absolout max from his standard parts
after a certain amount of fueling duration u allmost hit a wall so it takes a lot of fuel to keep incresing the power just by a small amount
but i think its safe to say he probably has the most powerfull semi standard pd170
i did run my pd170 and made good power and torque with my old 5ark map
I know plenty about modifying a TDI thank you, I had two and also helped a mate modify his hybrid Leon. There loads of big power TDI's. And excessive load of smoke is just a pirate way to mapping a diesel. A bit of smoke is acceptable, not loads of it where you can't see out of the back window. But aslong as BIGG is happy with it is all that matters
suppose u can allways run a clean map and run your tyres at 20psi and hav it on the dyno to gain a fake 10bhptranny loss ftw
Thought you were meant to up the tyre pressures if you want to fake RR figures not reduce them?
wrong
if you put more pressure u will lower ur maximum figures
not goin to explain why
OOOOOOHHH! hahaha
