On there rollers my CC JBS map made....... 188.2 bhp and 414nm of torque. They then put a standard map on my car with my miltek exhaust and panel filter which made 167 bhp and 374nm.
They rolling roaded my car over a dozen times trying to get the map as aggresive as possible without the stuttering hwich it was doing a lot of on the rollers!
In the end the car managed to make on one of the last runs 217bhp and just under 500 nm of torque which equates to 370 lbs ft of torque. Mikko and Ben both said if the car was cooler and hadn't been run on the rollers so many times they believe it could of made over a proper 225.
That JBS map was the WILD map and only made 188 bhp on there rollers....
As i said there rollers musta been spot on if not under reading as the car with a standard map dpf delete full miltek and panel filter made 167. The leon FR;s standard torque is 350nm and it made 374 so the torque may have been increased with these mods. Mikko told me he reckons if you put it on other Dynos Dyno Dynamics, Dastek etc you will see some big readings. The car itself is rapid! I can't stop driving it!
So when you look at it like that when JBS stated my car and dynoed it at 240.6bhp and it made 188 bhp. And then after making 216 with it heat soaking to hell that is a big jump and going from 414nm to just under 500 on my best run is a lot as well!
Max Bhp is made all the way up to 4666 rpm.....
