Righto I though Id do a Bt Thread for people to Follow as My RR is about everything lol..
Anyway Il Start this is a INA Engineering BT Build kit And a fully Built Motor with OE Displacment On a Cast Top mount Manifold along with a FP HTA 68R...
I First started off with the Engine along with striping it down and then Starting from the Base and building upwards.
My ''OLD'' K04 Setup removed..
Once that was done i Began to strip the motor down and start to order the following bits
Then Stripped down the OEM Pistons and Fitted My DM Rods and Cleaned them up..
Before:
After:
Now With it Hone'd and the Block Clean we started to build the bottom end up:
Degreased Sump
New Pistons Fitted With New OE Rings,ARP 2000+ Bolts & Veins C'Rod Bearings
Once that Was Complete It was on with the BAM Head Rebuild...With the horror storys i was hearing i could'nt do this on my Own So i got a Really Good friend todo it for me..
New Ferrea 1x Peice Exhaust Valves & Veins OE Inlet Valves Along with Full Cylinder Head rebuild gaskets & Followers Ect.
Before:
After:
Degreased Sump
