i think if you look for golf trim clips on ebay you should fins what your looking for
Has anyone else broken clips and not put in new ones and have found the door creaks when the car is in motion or is it just that I haven't fitted the card back on properly? Its winter and I dont want to take my door apart again.
- I don't think you need to run a new seal around the whole plate. The seal is critical to keeping water out on the bottom edge, but elesewhere doesn't really do much so I reckon you could get away with replacing the lower half of the seal only.
I seem to remember breaking more than half of the clips, but the runner at the top and the screws at the bottom seem to keep things quiet? I don't know whether it's because my doors are leather covered rather than plastic though.
I really ought to buy a bag full of those clips and refit them!
My passenger front and rear foot well is wet all the time the rest of the car is dry, now in the morning after a down-poor when I first pull-away my other half's feet get rained on and soaked, seems to be coming from under the glove-box and yes its funny when she shouts at me but I need this sorted!, would it just be the filter? Many thanks
Do i need to buy clips as well? Assume ill need the strip for driver and passanger side doors. They are the only ones leaking.
Chers
No, I used the car while the passenger seat was out (needed car while carpets were drying) with no such problem so assumed drivers side would be ok also.
Further research suggests I need to reset the fault code... does anybody have experience of using any of the diagnostic tools on Ebay costing about £20ish, e.g. Ebay item 150667799048 - probably cheaper than paying a main dealer to do it.
