got a few more pics in the clear sky so you can see how it fits to the turbo.
Hi Mate,
Just looking through the thread and wondered where you have cut your crash bar have you just left it or welded the back section with a new flat piece to retain strength?
Currently fitting the exact same IC and at the point where need to cut the crash bar.
Kyle
Hi Mate,
Kyle
I have just cut a section out did not weld in any steel bar to strengthen maybe I should have!
3inch intake up and running and logged no real gains from this 3inch intake setup at all infact it seems to have lost power but i think my maf might be failing and a lot of other things to take into count like mbc fitted after.
but does look a lot better i think anyway. logs before and after
sounds a lot nicer.
Code:
3inch intake cfs a little high 24psi boost.
	Group A:	'002				Group B:	'020				Group C:	 Not Running
		RPM	Load	Inj. On Time	Mass Flow		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME					TIME
Marker	STAMP	 /min	%	 ms	 g/s	STAMP	 CF	 CF	 CF	 CF	STAMP
	9.09	1280	88	9.02	23.28	9.49	0	0	0	0
	10	1480	94.7	9.43	29.08	10.4	0	0	0	0
	10.8	1640	102.3	10.25	33.28	11.2	0	0	0	0
	11.6	1880	111.3	11.48	42.53	12	0	0	0	0
	12.4	2160	142.1	14.76	62.33	12.8	0	0	0	0
	13.2	2480	173.7	18.04	89.44	13.6	0	0	0	0
	14	2880	191.7	20.91	115.72	14.4	0	0	0	0
	14.9	3480	191.7	23.37	147.11	15.29	3	3	3	3
	15.69	4000	191.7	22.96	173.5	16.21	3	3	3	6
	16.7	4560	191.7	23.37	195.33	17.1	3	3	3	6.8
	17.5	5000	191.7	23.78	208.11	18	2.3	5.3	2.3	6
	18.4	5360	191.7	22.55	209.14	18.8	2.3	5.3	2.3	6
	19.29	5680	191.7	21.73	209.58	19.69	2.3	5.3	2.3	6
before
Code:
	Group A:	'002				Group B:	'020				Group C:	'004
		RPM	Load	Inj. On Time	Mass Flow		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Voltage	Temperature	Temperature
	TIME					TIME					TIME
Marker	STAMP	 /min	%	 ms	 g/s	STAMP	 CF	 CF	 CF	 CF	STAMP	 /min	 V	°C	°C
	9.9	1960	114.3	11.07	43.72	10.4	0	0	0	0	10.8	2200	13.65	97	29
	11.2	2360	165.4	15.99	80.89	11.71	0	3	0	0	12.21	2800	13.65	98	28
	12.61	3000	191.7	20.5	131.31	13	0	3	0	0	13.4	3520	13.02	98	27
	13.92	3800	191.7	22.55	169.53	14.41	3	2.3	3	3	14.89	4360	13.65	98	26
	15.31	4600	191.7	22.96	186.89	15.71	3	2.3	3	3	16.2	5000	13.44	98	27
	16.72	5160	191.7	22.14	195.97	17.12	2.3	1.5	3	2.3	17.52	5440	13.51	97	27
	17.92	5600	189.5	21.32	202.44	18.3	2.3	1.5	2.3	2.3	18.7	5840	13.51	97	29
	19.1	5960	186.5	22.14	212.47	19.5	2.3	1.5	2.3	2.3	19.9	6200	13.58	97	29
Update time. Got round to fitting my 2.75inch blueflame downpipe. Made a good difference to the g/s logs.
Second run and my clutch is slipping! So it is time to upgrade
Great progress, gave me a nice read start to finish, also you car sounds nuts in that video
Thanks mate glad you like it.:D
That clip is awesome mate
Hybrid sound's very hungry early in the rev's :D
Oh how i can't wait to hybrid mine
i have been busy the last week making a mould so that i can make carbon fiber cambelt covers. was not as easy as i first thought but got the mould made now. here where i am at so far.
Sweet. never knew you were up to this haha, I'll have to buy one off you once you got the mould made if you want to make a few bob. Got myself a new DV on the way and the coilovers are on so I'm starting to get there now - gonna order some rear spacers today.
Top work mate I got the first clear carbon one made today but I need more practic it's been a long time since I did clear polly work so used the first one as a fitting piece works so far.
