not a today, but Thursday fitted AP coilovers :)
Took my car to the Audio specialist coz my Amp is fookin up AGAIN, ended up not fixin it but buying a secondary amp well cheap!!! 500 watt by 2 channel planet audio demon!! Gonna be running 1100 Watts total with a separate channel per speaker eventually... Can't wait!!
Change my first brake drum (micra rear) omfg I was right to steer clear for all these years lol fingers hurt and spent 2 hours outside on the floor = cold...... I'll do the other side today ;)
Do the rear passenger lights just pop off as i have the bulbs to do mine but thought I was about to break them!!!
It's hard to explain and a mega pain to do. You have to pull one side of the light surrounding out from the roof lining and the little bulbs screw off from the back of the unit, I used a mini flat head to get to it. When I pushed the light back in it didn't sit properly, this is because I bent the metal surround, just bend it back and it's fine.
Following advice from andycupra and LEE69, my LCR had a new thermostat fitted yesterday.
Consequently, MPG on local roads has improved from 23 to 32, which is approx an extra 108 miles from a tankful. :)
changed over my knackered crankcase vent pipe, put in some led sidelights and ordered some 6000k hids off the bay.
Busy day in all :)
old vent pipe
not much left of it
shiny new red silicone pipe
only problem is the new pipes wider so i cant fit my old engine cover back on :(
Hello mate can I ask where you got the pipe from
not today but sat fitted 2 trackrod ends and a steering rack end along with a wheel speed sensor
to find the fault is still being thrown up for the wheel speed sensor !!!!!
got to say my fabia rear wiper still going strong , fitted it about a week ater buying the car (still on original blade it came with too !!!! )
Ordered a set of LED bulbs to do the whole interior + rear number plate and also a set of Falken 452 tyres.........oh and booked in to get the wheels powder coated next week :) :)
Can't wait..........
You will have to let us know how you get on, I here'd that when shot blasting them it can reveal a lot of pitting because the LCR alloy is a mix of materials and not all alloy?
