god sake, this debate still going? decats will pass the mot.. end of. smoke test only, and it would be pretty poorly to fail it too as the the car isnt even under load!
Just had my decat van mot'd and I've had a look at the new guides inspectors have. Friend of the family is a chief mot inspector for a council where I took said van. Loads of pointless things coming in this year, mainly electrical and light covers etc tints. No cat info.
Plus the new crap paper mot which is a joke.
the mot tester yesterday told me the cat bit comes in in may just a visual inspection and if your car is meant to have one and its been removed and they see its not there then its a fail
then he's been given the wrong advice then simples...
I've seen and spoke to the chief mot inspector for my local council.
He doesn't run a garage, nor work for one. So its no skin off his nose if you fail or pass. He only fixes council vehicles.
They mot a very small amount of private vehicles and mostly mot taxis etc.
like I said before, changes are coming in like dash error lights, tow bar electrics, and tints applied to headlights, nothing for cats.
Below is the actual revised quote from the 2012 MOT testers manual, its syntax is detached because it comes under the column heading of "Method of inspection"
So the statement would read
Quote:
3.On vehicles that qualify for a full cat emissions test, check the presence of the catalytic converter.
It seems quite clear that the presence of a cat will only be required on vehicles requiring a "full cat emissions test" and because diesels only require a smoke test, a cat would not need to be present.
That said I wouldnt be supprised some garages failing diesels that didnt have them, as they don't understand the rule!
