I'm pricing all my hosing up today whilst at work lol. Here till 9 so may as well. I think I might go for some thicker hoses tho so it looks a bit more beefy in the bay so thinking 76mm so will bed a 90 51-76 reducer Bend then to a 76mm 90 bend then a 76mm straight piece to the filter. Bit pricey to do this tho lol
Here Is The Print Screen Of My Order Plus £3.51 For Vaccum Hose That I Ordered Seperately
Lol Looks Similar To Mine, Only Difference Is Mine Has A 50mm Alloy Pipe Inside The Two 90 Degree Bends So That I Can Tighten The Coupling Over The Top Without Squashing The Silicone Pipe, And Then The alloy Pipe Goes Inside The 76mm Bend, And Then A Coupling To Connect The Filter And Alloy Pipe :)
that is the old breather filter in that picture, i dont actually know how big it is,
my new one is around 13mm i think, ill check and get back to you
Have you got a link to the same one you have? Also where did you get the red hose from that it's attached to? Is that hose needed or can the breather just sit on top of the engine?
Yes 13mm for breather filter and if you want the pipe just type in 10mm silicone hose and order 1M of it. Ideally the any air filter needs to be away from the engine but people have just plonked it on there. If your just plonking it on engine then you'll need a 10mm filter. (all dimensions ate inner diameter)
Sam.
Sam.
Thanks, have just ordered everything that I need, now just need to wait for it to all be delivered :)
