having the boost pushing against the spring ??? So on full boost there's a chance of boost leaking past ?? They shouldn't be run in reverse .
i maybe be wrong but when boosting in theory the boost pressures on either side of the piston will be equal as the small vac line will be under boost pressure too as it comes off the inlet mani plus the spring pressure holding it down will make sureit wont leak???
only an idea
