3" downpipe fitting price
  • Thread starter Deleted member 12147
  • Start date
AshFR
Seat Leon TDi PD150 2005
Mar 10, 2011
385
Shropshire
photobucket.com
I paid £40 to have my full turbo back milltek system fitted on mine. I know awesome wanted £120 so i was happy with the £40. They had to do one cut on the old exhaust but ive got that so if i need it to go back on for whatever reason, i can with a quick weld or clamp :D
Well I went out and got some:
Cheers, did you do the decat/cat pipe to? Also did you wrap over the sensor hole then cut the wrapping or do you wrap around it?
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
no i didnt bother with the decat,not worth it imho as is under the car. i wrapped over the hole then cut a slit in it to allow for the sensor.
its surprising how much wrap is needed to do just the down pipe, i used the whole roll on the dp. if you have enough after doing the dp wrap it again as 2 layers is better than one. also word of warning dont wear decent clothes as its messy stuff :)
sambryant
Mar 26, 2009
4,848
Bristol
Whats the reason in wrapping guys?
retains the heat, hotter gasses flow better, helps keep engine bay temps down. also with our style dp i feel the wrap slows the cooling process down meaning the dp will less likely to crack on the bend, this has happened a few times now. all small positive things so its worth doing imho.
leoncupra2012
657
Did someone just say 4 hours to fit a downpipe/decat?
I walked into a tyre/exhaust garage near mine, had a whole stainless system, downpipe, decat, mid and rear box fitted in an hour £120.. lol
leoncupra2012
657
Are they that much different? I know where the cat joins the midpipe its a bolted flange fitting where on the lc180 like mine its sleeved, but the rest of the system is bolt on?
AshFR
Mar 10, 2011
385
Shropshire
photobucket.com
1 hour for £120. They saw you coming mate. Awesome charge £60 an hour and they said 2 hours to fit on a PD.
That's a shame i only paid £40 mates rates after work :p
I paid £40 but thats wasnt mates rates. Just was just normal work time lol. And the did a cracking job like everything they do with my cars :D
How much was on the roll you had? It would just be my luck that I haven't got enough.
