Is there any possibility to update the ECU without changing the unit itself? Maybe a remap...?i tried 4 split r valves and got limp mode every time in every setting. from what i gather only certain types of ecu will tolerate the air leak without going into limp mode. getting limp mode from a split r valve is not a bad thing, it means your ecu is doing its job. my open cone filter with a forge 008 dv is much louder than the split r.
This doesn't sound good...Some LCRs run fine, others don’t like it all and go limp regardless of the settings. It’s the limp mode lottery and it sounds like you’ve lost.
My advice would be to sell it and buy a recirculating dv like the forge 007p and 008. Then go for a open cone filter to get the dump noise.
Thanks, I'm experimenting a little before doing this.Thats true, if you cant get it to work, just go full DV mode with it.
I didn't clear the fault codes yet, maybe that's why I keep hitting limp mode in every setup?Default Forge setting is 16 clicks if I remember it correctly. Mine is still set at 16 clicks, yesterday when pulling up full throttle, I received an error (System too lean, interemittent, thank god for vagcom). I cleared the code when I arrived home and went to 15 clicks.
LC180, non mapped. Powerfilter, Toyosports tip, Powerflex dogbone.
I need to get a boost gauge to check exactly which condition I get limp mode...I hit limp mode (0.4 bar if I remember correctly) with 17 clicks, when I clicked down to 16 I could hit normal boost again (0.8 bar), but the error remained (cleared it as soon as I arrived home).
I'm a little bit afraid of cone filters. I've heard a lot of bad things about them. Now I'm using a K&N panel filter, I don't want to do any harm to my turbo.![]()
