cordoba lad
Back in the Midlands
May 24, 2005
180
Warwick
Fitted superpro rear beam bushes today just need to bleed the brakes now. 1.5hrs to get the old ones out 30 seconds to fit the new ones.
nd-photo.nl
4,429
503
The Netherlands
youtube.com
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
Added another layer of fiber glass to my ongoing stealth sub box creation.
Gave Adrian flux another £172 to up my milage as I was nearing my declared annual mileage after only 6 months.
But they also added an air filter (for aesthetics and sound, not performance) to my mod list for me for free,
Now I need to find some where to get a big blue cone filter and all the bits to fit it.
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
Thanks Lee. I have been trying to find out what one is better to get and what other parts I will need all day, I know I want a jetex one as the reviews are great and the blue will match my theme but is there any point getting a massive one as the maf pipe has an area of about 38.48cm2 so surely a bigger cone won't allow more air to get in the pipe :confused:
Exe_LeonCR
Exeo ST
Feb 12, 2012
284
Devon
Did the N249 bypass and put a few holes in the airbox while i had tools out.
Happy with the sound difference and smooth turbo.
LCRnorwich
51
Fabricated 2 nut and bolts to hold my pollen filter cover on, and removed and fixed my Aura? CD changer as all I was getting was the "changer" error message.
greck999
SLOW work in progress....
Jul 10, 2009
396
Rugeley, Staffs
Refurbished a set of wishbones with
Powerflex bushes, New ball joints and droplinks. Ready to go on.
Hopefully get rid of an annoying knock....:rolleyes:
Sent from my HTC Desire S using Tapatalk 2
Steely
semiskimmed cupra R
Dec 30, 2008
1,425
Doncaster
is it me or does that right hand balljoint look twisted :confused: or have they both been built right handed?
just fitted 2 new front abs sensors on the front . it typically started raining and hailstones. :cry: damn the old ones are hard to remove. a bit of brute force and drilling i got the damn things out. new ones (£6.50 a pair) went in with a bit of a sand down and work a treat. mot for tomorrow morning. wish me luck.
oh and if the weather picks up ill fit my mbc to sort my boosting issues and ill also fit my new blue oil catch can. :blink:
test fitted my 20mm rear spacers. looks much better but need slightly longer bolts.
greck999
Jul 10, 2009
396
Rugeley, Staffs
It's my fault what a d*#?..
The ball joint on the left wishbone was upside down. Both sorted now..:rolleyes:
The part numbers sit on top when fitted to the car...
ladybird
166
Portsmouth
just fitted 2 new front abs sensors on the front . It typically started raining and hailstones. :cry: Damn the old ones are hard to remove. A bit of brute force and drilling i got the damn things out. New ones (£6.50 a pair) went in with a bit of a sand down and work a treat. Mot for tomorrow morning. Wish me luck.
Oh and if the weather picks up ill fit my mbc to sort my boosting issues and ill also fit my new blue oil catch can. :blink:
Test fitted my 20mm rear spacers. Looks much better but need slightly longer bolts.
good luck !!!;)
copey_cupra
Well drove it to work had it on the ramp at the end if the day to check my pipe coz I think there's a boost leak but all seems fine still not sorted booked into local garage
O and hovered her out while I was there
zorro
Got it back from the Body Shop after it got hit last week...seems like an age since i had it...happy boy :)
