joel81
12
Sorry about the length of the post guys but I've got two possibly related gearbox issues on my car and I thought I'd give as much detail as possible. It's a 2004 PD150 Leon mk 1 TDI which has now covered 100k miles
1) When bringing the clutch in and out when changing into and out of 5th gear there is a whirring / whining type noise, the pitch of which increases with the revs. It doesn’t happen in any other gear so I've been bypassing 5th for a while now, but there is a bit of noise in 6th that didn’t use to be there, particulary when lifting off. It's not much, a quiet whine, but it seems to be a symptom of the same problem.
The car has been in to a local garage to have the gearbox oil changed, this has made no appreciable difference but did reveal the oil was dirtier than they'd have expected. Susbsequently it's been in to Geartech near Kidderminster who say the issue is the 5th gear bearing wearing into the casing of the box and it's a common issue on 6 speed VAG boxes. The fix is to replace the input bearing with a larger one (as used on later boxes) and this means machining the casing to accept it. Some of my recollection of the technical details may be slightly off but it all seems to make sense. The fix obviously isn’t cheap (£600 odd assuming the gears themselves aren't damaged) but apparently works and is better than a recon box as it won’t happen again. Is this something others have experienced and is it worth doing or can I continue to drive around it without too much of an issue?
2) The second issue appears related, since the oil was changed the change from 1st to 2nd when the engine is cold has got very notchy and crunches in unless I change slowly and deliberatley. This disappears once the engine is warm when the change seems fine. Could this be related to the 5th gear issue or has low quality oil been used perhaps?
Obviously if I had the 5th gear issue attended to they could investigate the 2nd gear issue and also use high quality oil, the trouble is the cost. My other thought is then if the gearbox has to come out for work would it make sense to replace the clutch at the same time? It's absolutely fine currently but is the original as far as I know. If I'm doing the clutch would it make then sense to put in a Sachs type clutch suitable for a remap? How does the price of these compare to standard? If I'm shelling out for all of this I'll be keeping the car for a while so I'd want a bit of longeviety but I'd also be tempted by some extra performance.
Very common it seems. Mine whines a bit but it doesn't bother me to be honest. I shall get it done at some point.
600 sounds expensive though. I'm sure there was talk on here of 350 or thereabouts?
Coupld be a different issue though as it wasn't gear specific as far as I remember. Ie, all gears whine.
Do not overfill the gearbox!
You will damage the internals.
Be very careful about the advice you get from some people on here, they dont know what they are on with.
Pmsl, alright then. ever had one of these apart? the bearings are all splash fed by the diff. the lay shaft and input shafts are all out of the oil. have a read of a VWMotorsport manual when you get a chance. they specify to overfill by 1l.
Done it on mine. Done it on my ex's VRS. and several customers cars aswell. Never had a box failure. So, be careful about accusing people of not knowing what they're on about ;)
So your into reading what other people think may be a solution.
Changed my oil at 85k filled it to the correct level and had no gearbox issues at 157k when I sold it, still know what you are talking about then?
Yes the gears are are splaSh fed so why immerse some of the internals completely in oil.
Just asked a mate of mine who has been working on Skoda/ VW for over 20 years and his advice was to NOT OVERFIL THE BOX.
P.S WHY OVERFILL IT WHEN ITS CLEAR THAT EVEN AT 157K THEY STILL WORK FINE WITHOUT THE OVERFILL?
And no noise either?
Just text my mate who works at VW, in the last 10 years he cant recall an official bulletin advising service techs to overfill by 1l, they only carry 2.4l why overfil by nearly 50%.
Be careful!
There was never a service bulletin for it, Ive picked a box up with failed bearings on 76k, mine had bearing failure at 130k. I'm stating my findings. 1l is not enough to completly immerse them in oil. and is far from enough to cause any sort of damage. They're splash fed, but in town cars where the diff rotation isnt enough to supply sufficient amount of oil to the bearings, thus knackering them. I'd happily say I know what I'm talking about. But hell, then again, bearing failures or casing problems don't exist do they.
Take apart an 02j box aswell, crap oil supply to the 5th gear. Overfill by .5l and it solves any issues.
I had this exact problem after having my my gearbox casing shimmed. You guys think we should take them back and have them overfilled by 1L, or do we need to use higher quality oil?
Without us all falling out;
We all have different views an opinions, as a time served hgv technician, I would not suggest your remedy. If the manufacturer has not recognised it and approved a remedy then best to stick to the manufacturers details.
For those in any doubt my car never had bearing issues in 157k and from 113k to that mileage it ran 215hp and 390lbft.
I had this. Replaced oil (to correct level, BTW) and still had it. Turned out both front wheel bearings were gone.
Your prob could be wheel bearings, mine only whirred over 40mph.
Gone now.
I don't really get your point though mate? You have proved that with care they can reach 157k miles without work.
Thats not the issue though. The issue is regarding a box that is already fooked, so its just not particularly relevant i don't think? It may well be that ive missed your point though! :)
Be thankful you don't all have bmw auto boxes! The "change the gearbox oil / don't change the gearbox oil cos it will die" argument is out of hand!! lol
Manufacturers are hard to get them to remedy anything, I've served my fair share of time as a Renaultsport technician. Look at the amount of coils that have failed, VAG have only just recognised it as a problem. Why recall something that'll fail outside of warrenty? They won't. Manufacturers only build cars to last the warranty now. Look at all the diff rivets shearing on the lower spec models. No problem there according to VAG. But VWM have recognised it and state in all they're manuals to overfill by 1l.
From your statement about missing my point, I cant see any reason in overfilling a gearbox which is already damaged. Overfil may serve to quieten a noisy box, if it were to do that, but as said I cant say its a good idea. I think we have reached the end of the debate on this one now. Dan has his findings and ultimately if overfill proves to work then fine but its not something I would dare to do.
On the subject of gearboxes, when you change gear, any gear and then let off the clutch what is that metal slapping sound i sometimes get on my lc180, its the same sound the car would make if the engine was off, car was in gear and youd try roll it, it would roll a little then the gearbox would catch?
Sounds like i need to give the guys at Engine and Gearbox Centre a call or drop in then after your experience SubZero, seems to be a similar issue. My cars been all motorway miles since i've had it (25k or so) so with a bit of luck the internals should be ok. The £600 i mentioned did include removal of the box, i assume that was included in the £340 the shimming cost you?
I would say thats the DMF as its taking the load from the clutch, nothing to worry about.
Only seem to hear it more noticeably when going into 5th after changing gear, you can hear it do it in other gears but its not as loud, weird. cheers mate
