Bedford is good place to start as there is plenty of run-off should you overdo things and outbrake yourself into a corner. Don't know what circuit you did Jimbo, but if it was the full GT one it can be a killer on brakes as there are a couple of big heavy braking spots on there. Funny reading your costings, as when i've taken the GT3 round there I generally get through around 3 tanks of Super at about £90 a tank!! It's a big power circuit, and the worst mpg I've hit on there is 6.4mpg!!
BTW Jim, did you monitor you tyre pressures at all? This can have a dramatic effect on handling, and I recommend anyoone that's considering tracking to get themselves a GOOD motorsports pressure gauge.
For anyone else going to Bedford, be aware that they are VERY strict on noise limits, so some with open or very loud exhausts will struggle. If you're close to the limit the marshalls will let you out - you just have to spot where the noise meters are and lift a little
Glad you enjoyed it though - and keep it up!!
ok, finally uploaded
http://www.youtube.com/watch?feature=player_detailpage&v=M7-5Iml7vi8
and yes I need new wiper blades
The Pro-street-S coilovers are faily competent, I would advise to get an rear ARB to decrease bodyroll.
Thats a great video, wipers dont seem that badTrack looks like you can get some decent speeds up down some of the straights. Well done!
About 155 on the long back straight after the hairpin, then a gentle brake before flat through the kink.
Jim - it looks like your instructor taught you well. Nice lines through most of the curves on the video.
BTW - most tyres need air letting out as the additional work they do generates a lot of heat in them and they start to overpressurise; less likely in your case as it was quite wet on your day.
good video. i like the sound of the diesel. doesnt sound like one though.
did you ever look at the mpg ?
