W11TTX
948
Cheshire
Seen as I'm new thought id start a readers ride early so here goes.
Engine and drivetrain
CC stage 1 map
Piper centre section and back bax 6x4 oval
Scorpian decat
O2 spacer
Forge TIP
Forge 007 recirc valve
jetex racing 80mm large induction
3" Cold air feed
Home made heat shield
Oil catch can fitted (pcv removal)
n249 bypassed and removed (blue silicone)
Sachs single mass flywheel (lightened) and clutch kit (fitted at 76k)
Bonnet sound proofing removed
Silicone pipes (charcole canistor and expansion pipe)
Ngk bkr7eix spark plugs
2.0l tfsi coil packs
Chassis-Handling mods
AP coilovers (fitted)
Lemforder top mounts (front)
EKT top mounts (rear)
Powerflex front rear wishbone bush
Powerflex front wishbone bush
Powerflex front ARB bush
Powerflex Dogbone mount bush
EBC 10 grove disc + pagid pads
Interior
Alpine x305s head unit
Parrot bluetooth
California cents airfreshner
Exterior
LCR Ronal wheels sprayed gunmetal grey
Front grills sprayed black
Black insert in bumper (temp untill i get the bumper resprayed)
Bonnet bra
8k HID'S
Silver vision front indicators
Cupra badge removed
B pillar back tints
Fabia rear wiper
Cut down registration plate (might be legal might not be ha ha)
Fog lights removed for cooling
Hope you enjoy!
Here are some pics after a good wash, clean, clay bar, paint prep, deep polish and HD wax.
Cheers for the comments. Only had it a month so only ordered new brakes thy need to be fitted and the n249 bypass! There is a few more things I want to do but nothing major! Need the front bumper spraying as the laqor is pealing and come off in places.
Quick update, fitted Jetex induction kit ( thanks to cupra_mat ) and made my own heat shield to suit. Fitted a powerflex Dogbone mount and have on order a alpine x305s with hands free! More pics to follow this weekend hopefully
Few more pics as promised Jetex induction kit and heat shield fitted, just need to spray the heat shield and get a pic of silicone for the extension piece
Fog lights now removed for better air flow to the inter coolers and 3 air feed.
Dog bone mount fitted
Sound deadening removed
It's slowly coming along next is service and cambelt in a month or two and then to get the front bumper re-sprayed
Just a small update. Painted the heat shield black and got some wishbones on the way ready to be poly bushed.
not realy been on for a while but recently had two new front tyres pirelli pzero rosso, got the alpine x305s fitted with full parrot bluetooth kit, just fitted a scorpian decat pipe and will be fitting an o2 spacer in the next couple of days, will get some pics up soon when i get chance,
Another little update had these fitted last week along with a Sachs smf conversion and clutch kit along with slave and master cylinder as well
Steering feels sharper on turn in and doesn't feel too harsh or crashing either
The clutch has transformed the way the car drives , clutch pedal is mega light and the pic up is sharper and a lot more responsive !
Also fitted a scorpian decat as well before the clutch kit. And WOW money well spent the sound alone is worth it never made how much different the spool up is. Tourque feels stronger and comes in lower down the rev range, well that's how it feels. Had a few issues with post cat Lambda but fitted a spacer now.
Also had the pre cat emllight on before Christmas so that has been changed over but now need to get to the bottom of the p0170 fault code that keeps coming up!
More pics to follow once I get some decent ones
small update, after finding a split pcv pipe and getting a p0170 fault code every now and again iv just ordered a catch can 2m of hose and the tee piece so hopefully that will be here next week. Might tidy up the engine bay while I'm at It as well and remove all n249 bits that are left after the bypass !
Split pcv hose
So this is goin to be replaced along with all the other shitty pcv system that is prone to failure!
Hope you get to the bottom of that code. It looks like fitting the new per car lambda has cured mine. Good to hear good feed back with the poly bushes as well.
Looks great, very clean LCR!!
Am i right in thinking they are the older Audi TT Wishbones, my friend is building a mk4 golf at the minute and has these :D
They are the same wishbones as what came off originally! Iv got the old ones in the garage at the mo! Yeah ReDBull the lamba has cured my lamba code but now iv got this other one so hopefully the catch can will cure that as you can see in the pic the pcv system in fooked!
