Belly pan/sump guard... worth replacing @ £63?
Brettyboy
2,597
Exeter,Devon
I fancy one of those alloy ones that folk are making, save whacking things with the sump and it should last longer than the plastic one.
Been thinking the same,be nice & rigid & could do a built in sump guard,the std undertray hangs down which is a pain if ur lowered
Seatmann
Rough around the edges
Sep 16, 2010
5,541
10
Scotlanda
There was a thread on the ukmiv's recently about this, I can't remember the full thing but there was talk of this same thing. Other than the cut outs for the drivers side I can't see it being that hard to do. I think I would have a separate plate for access to the sump plug, something that just screws on maybe.
Haven't thought it fully through yet but am really keen. My engine bay is manky from living in the sticks so this would be extra welcome and I'm lowered 35 mm which on the Mk4 platform means my undercarriage does take a bit of a knock sometimes. That dip in the sub frame for the dog bone mount has hit off the deck a couple of times too.
Now where to get alloy sheeting and what thickness to use, that's the next question.
Brettyboy
2,597
Exeter,Devon
A hatch for the sump plug would be good,i was thinking maybe a 2 piece,thin sheet alloy at front & thicker alloy under the sump to form a sump guard,could attach padding from undertray for sound proofing & added protection
Seatmann
Sep 16, 2010
5,541
10
Scotlanda
Well 3 - 4 mm thick is fairly tough and not very heavy at all so I think i would just go with that thickness all round. Not sure about bending etc but I know a man who does lol
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
875
southampton
I just noticed mine is hanging on in pieces that have been cable tied back together by the previous owner.
Any ideas on how much these alloy ones cost?
turboboy111
445
Norwich
my under tray had been lost as soon as i bought it unfortunately I live in the sticks and my engine bay is getting very manky! iv just had to buy a replacement engine for my car and have painted the block e.c.t and really want a new under tray to keep the bay allot cleaner!
I have found one on ebay: http://www.ebay.co.uk/itm/VW-SKODA-...90310&pid=100011&prg=1016&rk=1&#ht_1652wt_962
not sure on quality however I don't want to be spending £63 on one!
i have been looking into metal/alloy sump guards popular over in the states but cant find any in uk so would have to be made, I would like to make a tdi 150 style long version any one got any measurements?
Seatmann
Sep 16, 2010
5,541
10
Scotlanda
They're just skid plates to protect the sump, they don't cover the underneath and stop muck getting in. I've just picked up a big sheet of galvanized steel that I'm going to use, make me a nice belly pan and finally stop the muck getting up into the bay.
My engine bay is total mank just now as i also live i the sticks.
Seatmann
Sep 16, 2010
5,541
10
Scotlanda
Yeh no worries, it can't be that hard anyway, just a sheet with a couple of bends at each side. I'll also need to add some bracing maybe to stiffen it up and prevent it sounding like a rolf harris tune while driving lol :D
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
You will need to fabricate some mounts to attach your sumpguard to the engine bearer rails. The undertray is only attached to the plastic bumper at the front and plastic side curtains, so if you replace it with a metal plate you'll end up cracking the bumper.
Seatmann
Sep 16, 2010
5,541
10
Scotlanda
I'm running it up the sides to attach to the front chassis legs where the plastic ones go. I'll also be attaching it to the subframe at the back, not sure about the front, might just bend it up in side the bumper but not attached as such.
Brettyboy
2,597
Exeter,Devon
Fitting the back of it to the subframe should be easy enough,maybe fabricate some brackets off the crash support bar behind the bumper
Seatmann
Sep 16, 2010
5,541
10
Scotlanda
Yeh I was just thinking about that, I don't think it'll need much but just a little something to make it more secure wouldn't go a miss. I need to also think about access to the sump so I'm not sure wether to have a detachable plate or just use some sort of plastic rawplug type thing so the screws don't seize in.
turboboy111
445
Norwich
when you make this if you could do a build thread think that would be amazingly helpful, how much was the sheet and where did you get it from?
