Ah the good old chatter debate. For the record I ran a standard t2 running a bar of boost with no dump valve on my Fiesta Turbo and it chattered its arse off. That turbo had been chattering for 10 years then I sold it and as far as I'm aware its still chattering today on the original turbo out of the factory. In the ford scene nobody runs dv apart from focus rs's unless stupid boost as already pointed out.
Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk 2
if these engines didn't need a dv then why did seat/vw go to all the trouble to design an engine with one fitted, surely it would of been cheaper not to fit one as you need extra pipe work and the valve itself, in my eyes if it there it's there for a reason
They are fitted as a noise surprising system. Not every one wants to listen to chatter
As per most Volos and sabbs, evos and subarus. Even later cosworths ran the crapy plastic bosh valve.
As I've explained newer stuff running roller bearing turbos do need them to save the turbo shaft.
I thought these engine/turbos where differnent to most other cars jap/ford etc
Thought the dv was more of a relief valve for the turbo?! If I have my turbo smart dv to far open/venting to the atmosphere it cuts out eveytime I stop :(
Not saying it is just what I thought, especially as my mate had knackered turbo/dv etc
I'd rather have it fitted as it was from seat but I do like chatter lol
I'm not saying you should all go remove them. I took mine of as the valve was fubar and I didn't want to buy another.
Runs perfectly fine. A turbo smart dv is not twin piston so will not idle. You need a baileys twin piston ( dv26 iirc) or equivalent.
stalling the turbo making it chatter isnt advised for these cars.
on RS's etc yes, i agree, and it does sound cool.
Im suprised your turbo is still alive after running no dv for that long.. :blink:
Re: Whooshy dump valves
Good post below from Max_Torque
"No rhime or reason"
But:
(and concentrate, here comes the science bit!)
A modern engine management system, ie the Bosch Me unit fitted to 1.8T's has "adaptive" learning on the fuel, ignition and airflow side.
Because Me is a Torque based structure it's calculation of engine torque verses driver demand is critical to the driveability of the car and it's performance / durability.
When you fit a "leak" in the intake system (open circuit valve) the original calibration of the MAF sensor to manifold and cylinder filling modeling will not corespond. However due to the 20% allowance in the long term adaptive values the ECU will relearn you engine and "leak"
At idle the inlet model calculated airflow will exceed the MAF meters measured output, and depending on the state of your particular components - ie MAF ageing / contamination, throttle plate leakage, Fuel tank purge vapour concentration this may, or may not push the adaptive to it's 20% limit. If it hits the limit the ME unit will run in FMEM mode (Failure mode and effects management) causing reduced system efficiency. The Me unit will use the switching signal from the lambda sensor to return fuelling to lambda 1, storing the correction as a map agaisnt airflow. and add this correction to the fueling calc when operating at non closed loop conditions, ie WOT, fuel injector reenstatment (after overrun shut off, traction control intervention etc.) Now depending on how you drive and how sensative you are this may or may not be felt by the driver during certain manovevers. The throttle plate position will also learn the new airflow to maintain control of idle speed, but you may notice poor engine load rejection, ie turn on the aircon and the engine speed varries etc. or engine speed flares on starts or when operating PAS when parking.
However in all cases this will result in "incorrect" fueling. Now by "incorrect" i mean, not as the manufacturer intended. A post MAF leak will cause rich operation initially, but the adaptives will pull fuel out and become negative. This tends to cause a rich to lean spike on tip outs and other throttle transient. Now it is extremely diffucult for an untrained observer to spot these effects as they occur mainly on throttle transients, when the average drive may not notice. Therefore you could say "why do i care?". Well, any AFR excursion from the intended fuelling set by the manufacturer will result in non-standard engine operation. because of the adaptives this is unlikely to cause immediate engine problems, but over the course of time will change things like catalyst ageing, exhaust and turbo charger valve durability etc. Manufactures spend millions accruing miles on development fleets so hopefully the customers don't get landed with big bills as time goes on, and with most modern cars life'd at 150k miles (min design life) this is a big task.
It is unlikely that this will result in any performance loss, as at WOT the system is open loop, but you may see the result of an open circuit valve oas over fueling on gear changes etc. (a tell tail puff of black smoke is what you can see, a 1200 degC Catalyst is what you can't see, as excess fuel when injection reenstates and excess air from overrun shut off period combine in cat)
Now as you can see this is a seriously complicated subject and i haven't even mentioned the dreaded EOBD or OBDII words yet. Typically Bosch Me units have approximately 9000 calibratable parameters (constants, maps etc) and an engine calibration program will take a team of 8 calibration engineers 18 months to do the basic mapping and OBD validation. These days it's no problem to do the basic fuel and spark mapping, maybe 4 weeks on a midlimit engine on a dyno, but the diagnostics and emmisions devs takes years.
Moral or the story, before you start playing with something you don't understand, find someone who does!(And not just thinks they do!)
(for anyone thinking, "hey what makes me such an "expert" on this subject?" then i'd better mention the last 10 years i've spent as a senior calibration engineer at Cosworth and Prodrive!)
(sorry , another monster post!)
Don't just blank the vacume of te top as the valve will be forced open under boost.
Like I said I'm not advising you lot to do it. But I personally do t particularly like any form of dv. As said planning on converting to t3 fitment when my ko-gay turbo let's go :)
My turbo smart is fine now just takes time to set up correctly, it is designed for these engine so all good when set up Nicely
