Yea that's the stuff I used pretty much. I didn't pay that much for the cooler. But yes it works out more than a single pass kit. Also you need to be able to weld on a map sensor flange to one of the pipes
My Wellcooler is semi fitted!
Not bad for a £200 cooler, that's Inc pipe work.
the cheaper one would be fine apart from its got 3" ports instead of 2.5" so you would need reducers to fit it to the original pipe work.
So how much did you pay for the cooler and where from
Exactly, but the size isnt a issue?
I looked at that size cooler and tbh when I measured up I think you would have to cut away to much of the crash bar. The size I have only meant slight bumper mods, it cdmfrom a guy called intercooler king on eBay and was cosmetically damaged on one side so was 50 quid cheaper.
I installed Ibizas SeatSport to LC but have to say that DIY custom pipes need lots of time and patience. Check my readers ride topic.
Oh and if you wonder why the pipes are as they are. Hot side on top and the cold on the bottom. It means that the hot air doesn't soak through the whole cooler so much when going slower.
Lodey were you able to have fully functioning fogs with that set up as I'm thinking of going down the same route as you but I want to keep my fogs:confused:
Na drivers fog had to go. The brackets right in the way of the pipe work. Also I doubt you would fit it the way I have on a small bumper Leon. Although I may be wrong
I have Fog lights with FMIC but I have CupraR front bumper. But same kind set up in TopSport (=Cupra) works also and you don't have to remove fog lights.
