Is it worth buying a dog bone mount for my fl leon cupra ?
What are the main benefits and is it easy to fit.
I have put the powerex insert in ( the yellow one ) and there is minimal vibration , if you were a normal passenger you won't even notice it.
What it has done is improve gear changes , in traffic say second gear when you were creeping and came off the gas the gear stick would move a couple of inches , now it stays where it is no movement at all.
If you have loads of vibration after fitting this mod you either have not tightened it properly and seated it properly or there is another issue with your car.
If you want less wheel hop then I recommend the WALk kit.. now there is something that really does make a difference.
