fitting 9's tyre help
benjiwales
benji
Jan 29, 2007
297
Penybont
Hi guys
I've got some 17" porker rims I wanna fit but need some tyre advice
The wheels have ET55 and are 7.5 wide front and 9's on rear, so
a. what width pcd adapters would be best
b. got some 205/40/17's for the front, would 215/45/17's be ok for the rear?
As for the suspension it's currently lowered 40mm on springs but I've got coilies to go one when I get 5
Ben
FR_MATT
1,388
I think the mismatch can cause problems with ABS/traction control as it thinks a wheel is going faster than the other. 40 also looks better imo
If you look in the mk4 FAQ section there's a what wheels fit thread and some porka ones in there to see what offset you want
benjiwales
benji
Jan 29, 2007
297
Penybont
http://www.willtheyfit.com/ put both tyre sizes in and you can see the difference in speedo, size etc :)
Also tyrestretch.com for how the stretch will look
Legends
cheers lads
Aug 31, 2010
1,023
Lurgan, Northern Ireland
195/40/17 on the fronts, 215/40/17 on the rears will be perfect stretch.
As for the adapters, do you want the wheels to be flush with arches or poking out or tucking in?
If its flush you want, go for 35mm front and 25mm rear.
